Post by teddysnyder31 on Feb 11, 2020 19:58:03 GMT -5
Looking for other people with TGB scooters wondering what type of hop ups you can do
Post by Zino on Feb 11, 2020 20:37:49 GMT -5
You have a great 2 stroke engine morini style. If you are mechanically inclined and were only going to do one thing
Up the displacement buy a 70 cc polini or malossi cylinder . This will give you more power top to bottom especially take off add a little top end speed .
Pipe 2 choices street or expansion tecnigas street type better take off a little bit more top speed . yasuni r expansion pipe higher top end from higher rpm power band . When you change pipes you may need stiffer clutch springs so you bog on take off till you hit power band you also will need lighter variator weights so you spin up and stay in the powerband as long as possible .
sport variator better shifting and higher gear ratio to add a few more mph .
If you do all 3 of these you go from low 40 mph to low 50's and be a very reliable set up .
600-800 bucks would have you rocking the block .
Post by teddysnyder31 on Feb 11, 2020 20:47:25 GMT -5
Post by Zino on Feb 11, 2020 21:52:32 GMT -5
Scootertuning.ca is a good vendor for morini parts . They ship out of Canada and stand behind there products .
Post by Zino on Feb 11, 2020 22:00:37 GMT -5
Sharp looking machine . The morini engines are solid . Looking over the specs a bigger carb would be advisable also when you upgrade pipes .
Post by Zino on Feb 15, 2020 11:34:06 GMT -5
Post by krisgenchev on Mar 8, 2020 23:29:58 GMT -5
I had the same bike sold it last year, it was doing 56mph gps . Had this parts: TGB Bullet 2017 Malossi Sport 70 cc Technigas Next R Naraku 17.5 Carb Stage 6 Sport Pro Variator Malossi Fly clutch Malossi Fly Bell Now the variator i was only able to find from maxiscoot.com, since the drive bush has and indent to go over the crank, very nice and solid bike, not that many parts options for it but its great. The only thing i didn't like is that i couldn't find a final gear kit for it, i had bought it brand new at the time.
