Post by pinkscoot on Jul 11, 2020 10:38:54 GMT -5
Post by ThomasTPFL on Jul 11, 2020 11:16:06 GMT -5
And wife thinks I should repaint the rougher one....
Post by aeroxbud on Jul 11, 2020 11:47:19 GMT -5
Love the little scooter dude.
Post by sevenninesandtens on Jul 15, 2020 16:20:18 GMT -5
Got another scoot coming to me for free.
Yamaha CV80 Riva. Not sure about the year. My neighbor commented on my Instagram post about being almost done with the Pink Vino asking if I wanted another one for free. She got it 7yrs ago and hasn't touched it and is sick of it sitting in her garage. She's a motorcycle lady not a scooter lady. So it'll be coming over to me.
It's a white one and is in pieces so I'll just have to rebuild it. Should be fun/a giant headache that'll make me wanna ride it into the Schuylkill river most likely.
PDub
Ann Arbor MEEEEEchigan
Post by PDub on Jul 18, 2020 8:52:10 GMT -5
Dumbest scooter thing I've done lately? NOT RIDE...
Post by aeroxbud on Jul 18, 2020 13:41:03 GMT -5
Dumbest scooter thing I've done lately? NOT RIDE... You must go and ride immediately. Do it right now.
Post by mrchilled85 on Jul 21, 2020 13:20:11 GMT -5
went out on the bike today forgot to put more 2 stroke oil in my tank and just run fuel :/
made it to work and on the way back soft seized ended up having to push it back half a mile as would not restart after adding oil so hope its just the rings gone and not the piston and bore
i have 2 big cans of fuel in the shed one thats premixed and the other is not mixed so think i put the fuel in from the unmixed can as was putting the fuel in at 3am when it was dark and with the unmixed can being dark green and the mixed being a black can i just did not see it right
Post by aeroxbud on Jul 21, 2020 14:53:05 GMT -5
That's really not good. Hopefully not too much damage.
Post by mrchilled85 on Jul 21, 2020 15:22:46 GMT -5
That's really not good. Hopefully not too much damage. yep then went to just put the top end on the other bottom end i build up last week and seen i had fitted the crankshaft back to front note to self dont start building a engine up after doing 12hr shift at work so just had to strip that apart put the crankshaft back in the freezer so i can fit it the right way tomorrow
Post by aeroxbud on Jul 21, 2020 15:49:44 GMT -5
That's really not good. Hopefully not too much damage. yep then went to just put the top end on the other bottom end i build up last week and seen i had fitted the crankshaft back to front note to self dont start building a engine up after doing 12hr shift at work so just had to strip that apart put the crankshaft back in the freezer so i can fit it the right way tomorrow Didn't you know two strokes can run backwards. Be fine! 😱 My son built the bottom end up. Then he had seen the Yamabond sitting on the floor unused.
Post by mrchilled85 on Jul 21, 2020 16:28:16 GMT -5
yep then went to just put the top end on the other bottom end i build up last week and seen i had fitted the crankshaft back to front note to self dont start building a engine up after doing 12hr shift at work so just had to strip that apart put the crankshaft back in the freezer so i can fit it the right way tomorrow Didn't you know two strokes can run backwards. Be fine! 😱 My son built the bottom end up. Then he had seen the Yamabond sitting on the floor unused. yep just was getting over worked at work i just did not have time to sleep or anything as i was getting home for 6-7hrs per day and in that time needing to sleep ,eat and get showered so was running on lack of sleep :/
claydoh
Post by claydoh on Aug 2, 2020 17:25:29 GMT -5
I bought a performance cooling fan for my Thunder, which came with a set of allen bolts attach it. As I was having a bad arthritis day, and I forgot to grab my allen keys, I decided to use the OEM bolts to attach the fan. Heck, they looked close enough to the same length. After discovering the scooter would not start, it looks my stator is not working. No resistance. The mounting holes are a little deeper in the fan than the OEM, and the allen bolts, after a second look, are definitely shorter. I am making a huge guess that I hit something with one of the bolts. I did not touch anything but the fan and shroud. I need to stop trying to be a mechanic. And listen to that little voice in my head that tries to be heard over the knee pain.
Post by oldgeek on Aug 2, 2020 19:46:23 GMT -5
I bought a performance cooling fan for my Thunder, which came with a set of allen bolts attach it. As I was having a bad arthritis day, and I forgot to grab my allen keys, I decided to use the OEM bolts to attach the fan. Heck, they looked close enough to the same length. After discovering the scooter would not start, it looks my stator is not working. No resistance. The mounting holes are a little deeper in the fan than the OEM, and the allen bolts, after a second look, are definitely shorter. I am making a huge guess that I hit something with one of the bolts. I did not touch anything but the fan and shroud. I need to stop trying to be a mechanic. And listen to that little voice in my head that tries to be heard over the knee pain. Yep, it's new stator time. That is really a bummer!
Post by milly on Aug 3, 2020 12:17:37 GMT -5
Done exactly the same myself put on a new stator then to longer bolts for the fan and no working stator. We live and learn.
claydoh
Post by claydoh on Aug 3, 2020 14:35:17 GMT -5
Done exactly the same myself put on a new stator then to longer bolts for the fan and no working stator. We live and learn. I seem to be living quite well lately
