Post by aeroxbud on Mar 23, 2020 4:22:00 GMT -5
Does sound like a regulator problem. Did you check what voltage your putting out?
Post by milly on Mar 23, 2020 11:50:35 GMT -5
No I haven't yet. With ignition on I have 12v coming up to the indicator switch. Not checked the regulator end to see if it pulses as should or ignition switch itself yet. I do have a spare flasher relay so may plug that into a live feed and test it that way as well so if regulator side on that part is duff I can then wire that in properly.
Post by milly on Mar 25, 2020 15:41:33 GMT -5
Installed a indicator relay bypassing the one in the regulator today starting to come together at last. Nice out in the sun to. I took note of others comments and got myself a fold up chair to sit on
Post by milly on Apr 2, 2020 13:41:04 GMT -5
Scooter passed mot today, bit slow and hesitant on acceration but get there. May get a new Keihin repair kit for carb. Damn indicators packed up when got home but that aint no problem fix another day. Bypassed the regulator in the end aeroxbud so I have indicators or rather did. I did use those scotch blocks which sometimes dont make good connections.
Post by aeroxbud on Apr 2, 2020 14:29:08 GMT -5
Excellent news. Lot of bike shops are closed here. That's you're problem right there "scotch blocks."
Post by milly on Apr 2, 2020 17:01:12 GMT -5
Excellent news. Lot of bike shops are closed here. That's you're problem right there "scotch blocks." Indeed but they were only temporary till I can get some decent connecters 😊
Post by aeroxbud on Apr 2, 2020 18:47:53 GMT -5
Post by milly on Apr 6, 2020 12:22:22 GMT -5
Well scooter all fixed up and running. It feels quite slow indicators now work but erratically. The flat battery could have been where I left indicator's on as they were separate to the ignition switch. I had mechanic check charging and whether it was draining. Give it a couple of days standing then move it on I think once found my spare flasher unit.
