Post by mmandia99 on Mar 18, 2020 8:05:53 GMT -5
How to you put the center stand on the Icebear 150cc? It didn’t come attached and no directions
Post by jackrides on Mar 18, 2020 10:37:02 GMT -5
Don't know Icebear, but a strong spring requires a hooked spring puller. Nothing else works as well.
Post by jloi on Mar 18, 2020 11:44:59 GMT -5
this might be similar - and work for you.
Post by jloi on Mar 18, 2020 12:22:44 GMT -5
this vid isn't what you need to do on yours but it might still be educational/informative for you.
Post by mmandia99 on Mar 18, 2020 18:45:43 GMT -5
Thank you!!! I also noticed that the wiring for the turn signals that are inside the mirrors are not color coordinated?? How do you know what wires go where???zero instructions
Post by jloi on Mar 18, 2020 19:32:19 GMT -5
not sure, never had any . don't think there can be more than 3 apiece tho . process of elimination . probably only 2 apiece. power and ground.
Post by christopher on Mar 19, 2020 5:24:55 GMT -5
Post by mmandia99 on Apr 10, 2020 15:40:24 GMT -5
Thanks again for the videos!! Worked perfect!!
