Post by milly on Mar 18, 2020 16:06:08 GMT -5
Well I got the scooter running but now need to connect the above up. I can see no info or pics anywhere all I have is the pipe blowing blowing hot air out of the right hand side and the sas unit sat in the topbox with two pipes leading off it.
Any info much appreciated.
Post by milly on Mar 19, 2020 18:50:48 GMT -5
I found the way it works now here are some pics if others have same problem. Pipe it fits to to right of cylinder head which blows out hot air
Said unit Fitted item with pipe running under carb to nowhere as not found any other bit.
