lennie86
Scoot Junior
Freezing
No spark
Mar 25, 2020 13:05:25 GMT -5
via mobile
Post by lennie86 on Mar 25, 2020 13:05:25 GMT -5
Please help I purchased new stator/magneto. I also installed new CDI and starter relay and coil and new spark plug. I installed new magneto xx had spark it started than died. Now the light to my new CDI doesn’t blink, it doesn’t have spark. Please 911 this is my only mode of transportation. Someone help
Post by jackrides on Mar 25, 2020 14:59:48 GMT -5
Many scoots have a switch on each brake and it necessary to hold a brake so the switch will let the ignition fire. What brand and model? Do you have or can find a wiring diagram?
No spark
Apr 10, 2020 10:28:37 GMT -5
via mobile
Post by sjfishon on Apr 10, 2020 10:28:37 GMT -5
Same thing happened to me,after checking everything. I found the problem,If you look at the white plastic plug that plugs into the vid,you will see a red wire with a white stripe,that wire is the spark plug.I gust pushed on it and heard a click... Problem solved..check those wires
No spark
Apr 10, 2020 10:30:09 GMT -5
via mobile
Post by sjfishon on Apr 10, 2020 10:30:09 GMT -5
In my post I mean CDI
Post by collinsd84 on Apr 13, 2020 16:10:39 GMT -5
Make, model and year will help. Is there an antitheft switch on the scooter somewhere? Silly me, I once ran the battery down, and was offered a jump. Then I realized that switch was off, Duh! Check the kill switch too, just saying from experience.
