Post by mikeboogie on Apr 21, 2020 12:00:58 GMT -5
Thank you all for the suggestions I really appreciate it. I'm not looking for crazy speed increase for highways just better torque and a few mph increase would be nice will these get me that? I received these yesterday I'm a noob but hopefully If i watch a video I'll be able to install this myself if not I'll pay someone to help me... amzn.to/2Vjh6g7amzn.to/3eDLhqfI also installed one of those CDI + Ignition Coil kits.. bit.ly/2RX4Z6j
roon
Scoot Junior
Post by roon on Apr 22, 2020 11:38:17 GMT -5
The bore kit and carb look fine, I installed the same Goofit kit a couple of months ago for a friend and no issues so far. Watch the videos in the tech section or others on youtube. A regular set of metric hand tools should get the basic job done. The only special tool you might need is the appropriate feeler gauge(s) to set valve lash.
Try the new coil and CDI after you get it all set up with the stock parts, change one thing at a time. I have had little luck with those, coils seem OK but the CDI's are failure prone, I should have learned the first time I pushed it home. I would stick with stock unless you feel a definite improvement once it is all dialed in.
Post by GrumpyUnk on Apr 23, 2020 13:00:17 GMT -5
Personally, I would send back the 'performance CDI and coil'. If you take apart the blue CDI, you may be surprised at what's inside. From what I understand, they offer no improvement in performance, and just waste your money. The standard black plastic CDI modules seem to work fine. I would get a spare to have in case of failure, but not the blue or orange setups. I used a Glixal bbk and was pleased with performance and quality. You should use a torque wrench to tighten the four head stud fastener nuts. I think some manuals specify too much torque, so I would go about 10-12 ft-lb instead of the 16-ish recommended. It just feels like too much strain for the fasteners involved. tom
Post by mikeboogie on Apr 23, 2020 21:00:18 GMT -5
So much great information thank you all i really appreciate it...
