Post by milly on May 18, 2020 16:08:50 GMT -5
But with a differance , have V5, Mot, it all works and service history and handbooks.
A Vespa ET4 125cc. I already have a spare engine I bought yonks ago and some other associated parts Being delivered by courier sometime this week.
Post by pinkscoot on May 18, 2020 18:10:51 GMT -5
Good find. Add another 20 mirrors and finish modding it.
Post by milly on May 21, 2020 15:03:19 GMT -5
Post by aeroxbud on May 21, 2020 15:17:22 GMT -5
Looks like a nice bike Milly.
Post by milly on May 21, 2020 17:20:36 GMT -5
I think it will be around a while, I also have a spare engine I have had sitting for years for it as well for parts. I have heard the odd ting now and again when starting sounds like the bendix is not moving back quick enough from the variator when starts buts thats nothing complicated and the kick start quadrant slips by now and again but dont expect perfection at the price aeroxbud
Post by pinkscoot on May 21, 2020 17:26:31 GMT -5
milly My ET4 does the same thing when starting and I have been told the kick starters are sh*t, my CVT cover is cracked and the whole thing is pulled out now. It's hard to explain how nice Vespas handle. They are small and nimble. I like the floor board height. When I ride others I never left my feet high enough. They are very well engineered. Working on the engine is both great, if you only need to deal with something on the top. Pulling the spark plug takes some one with a small hand and long fingers. Enjoy it it will be a keeper.
Post by milly on May 21, 2020 17:40:18 GMT -5
Thank you pinkscoot for that info I shall use bits off my other engine just incase of flat battery at any time but I would like to get a 150cc barrel and piston for it same as the US market and put it on the spare engine but taking time when I can find a kit.
Post by aeroxbud on May 21, 2020 17:59:10 GMT -5
My wife has the same preleader engine in her Aprilia. They are pretty robust. Here has always made a metallic clunk when starting. I think it's just the way some are. They do like a good battery.
Post by pinkscoot on May 21, 2020 20:32:14 GMT -5
Thank you pinkscoot for that info I shall use bits off my other engine just incase of flat battery at any time but I would like to get a 150cc barrel and piston for it same as the US market and put it on the spare engine but taking time when I can find a kit. I think you could go to he Malossi 190cc barrel. It would give you that much more ump I'm sure its available in your world.
Post by aeroxbud on May 22, 2020 5:00:57 GMT -5
Post by milly on May 22, 2020 9:33:58 GMT -5
I thought the right side looked slightly duller than the other but not had chance to look proper. Anyhow put petrol in and it spilled down right side wiped with a rag and the paint came off. Looked further and could see that side and front panel had been rattle canned so mate at garage said he would use two pack on it if I rub it down and other side is fine proper paint.
Post by milly on May 23, 2020 8:57:00 GMT -5
Inspection time today, looks like some welding needed underneath bit crunchy. I do not see any repair sections online unless I have missed them may have to make them up. Hopefully not though.
Post by pinkscoot on May 23, 2020 15:34:07 GMT -5
That's bad. Time for some sheet metal patching. Most people just weld in what it takes to make it solid.
Post by aeroxbud on May 23, 2020 18:22:10 GMT -5
Post by milly on May 23, 2020 19:29:39 GMT -5
Thanks for that I looked at that but its the plastic panel that sits above it.
