Post by CrankingWithCG on May 23, 2020 19:22:28 GMT -5
Ill put a video, where the problem is shown and explained, but its also very stuttery at low throttle, af screw on the air side turned only half a turn out. When i can launch it good, it pulls so hard. Im just not sure youtu.be/SD2tvLpvEz8
Post by rocketdogiv on May 23, 2020 20:37:59 GMT -5
We need some more info Big. Tell us more. Stock, altered, I'm afraid I don't know what a PE28 is. Are you talking about a stock 24mm Carb? If it is that's a fuel screw not an air screw. I've never seen a CV Carb with an Air Idle screw.
Post by CrankingWithCG on May 23, 2020 23:31:34 GMT -5
We need some more info Big. Tell us more. Stock, altered, I'm afraid I don't know what a PE28 is. Are you talking about a stock 24mm Carb? If it is that's a fuel screw not an air screw. I've never seen a CV Carb with an Air Idle screw. Stock internals 150, its a 28mm Keihin roundslide carb with an ncy intake and a near straightpipe exhaust. It has the air fuel screw on the airbox half of the carb and not near the intake port, so screwing in cuts down the air.
Post by rocketdogiv on Jun 22, 2020 19:34:58 GMT -5
Ok. I think a 28mm slide carb is too much for a stock 150cc. It sounds like it's running too rich. I've tried and never gotten one that large to work well.
Post by eric67m on Jul 8, 2020 22:25:45 GMT -5
Things seem semi tricky to tune at times.
I currently have been messing around with the stock carb on my stock 150cc swapped into a Honda ruckus. The gy6 is all stock other than the exhaust which is larger diameter and a uni air filter. I also have a wideband AFR meter on it.
As it was originally after a WOT run the meter would drop from 13 down past 18,20,24+ running really lean. I kept cracking and breaking exhaust near the bend. The idle jet that was in there was marked as a 32 but was shorter. I replaced it with a longer 35 and then a longer 32. I now am running with the air/fuel mixture screw all the way in on this tiny jet and I am recording readings of 15-16 on deceleration and an idle mixture of 11.5. I cannot get any leaner...
I'm just still trying to figure it all out and keep it running. Fun times.
