Post by GrumpyUnk on May 26, 2020 11:36:18 GMT -5
Trying to figure out which kit to install, I was comparing some 47mm BBKs I have on hand. Paying attention to how freely the piston moved in the bore when the cylinder was rotated 180, I finally noted the piston tops.
Some have a small machined area (button) in the center, others have a larger button. One has no 'button' area at all. They all are concave when laying a straightedge across from side to side. It seems the dish is similar, though I did not measure.
I then took out the latest 39mm piston/cylinder I had replaced. Its crown(piston) was convex. The crown had a dome shape to it.
We all have mentioned increased compression pressure due to using the original stock cylinder head. I had compared 39mm heads to '47mm heads', and it appeared that the 47's had a machined area around the diameter while the 39's had a flat surface all the way across.
Considering the use of a 'fire ring' on composition head gaskets, and the burned away steel on an original stamped steel head gasket, I got to wondering how/where the fire ring would meet the combustion chamber when installed. Using a 39mm flat faced head, the fire ring would be recessed or sandwiched between the bottom of the flat head surface at whatever diameter, and the top of the cylinder wall, again at whatever diameter the fire ring happened to be( I assume(?) at 47mm+xx).
If a head designated for 47mm use was installed, I have no idea how the gasket would be fitted, i.e., how it would be protected or not from combustion gas and heat. Given a groove is machined into the bottom of the head surface, exactly where would the fire ring sit.
I also wondered what the 'dish' in top of the 47mm kit pistons does to compression ratio. I know it should lower compression, but have not measured the compression result for a 'good' 39mm engine to compare. For that matter, have not measured those for a 47mm BBK after assembly. So, there is a recess that lowers peak compression, so it seems the kits were designed for the situation where you do want to limit compression ratio. (Otherwise why cast in a recess and then do some machining to it?) The 39mm are not machined, at least not to any discernable finish. The 47mm pistons, all I have seen, have a non-polished surface, appearing to reflect the finish of the casting mold. I just realized the need/use for the center machined 'button'. That's where the mold injected/flowed the heated aluminum. The 'sprue', I think. The passage for liquid metal would be attached somewhere to the cast piston, and that makes good sense. Cut it off with a saw, and then polish the surface to eliminate any 'hot spots' on the top of the piston when in service.
Any thoughts on what the depression does to the CR of these kits?
tom
tom
