Post by Kenho21 on Jun 21, 2020 14:22:57 GMT -5
Right on. I was between a CP 19mm and PHBG 19mm when I was building my Zuma, so now I'll have options. I might have to throw this on the Zuma so I can compare the two. I know most of 49ccscoot loves these things. Strip it down when you have time and see what parts are in it, including the needle jet#. I'll take a look soon. Hopefully I can find some jet kits and whatnot. I know these have all sorts of adjustments that can be made.
Post by aeroxbud on Jun 21, 2020 14:27:44 GMT -5
it says delorto on it aerox lol I know. That's what I was saying! 😉
Post by matlock on Jun 21, 2020 14:51:58 GMT -5
aah yes you did say that exactly my mistake aerox
Post by Zino on Jun 21, 2020 15:06:09 GMT -5
25 bucks is a steal for a dellorto carb . even if you have to get jets and needles you wont have more than 75 bucks in it total after cleaning
Post by Kenho21 on Jun 21, 2020 18:01:35 GMT -5
Got it home and this thing looks like it's barely been touched. I opened up the float bowl briefly at the sellers house and it's perfectly clean inside, aside from a little 2T oil.
It is missing the spring and retaining thingy the spring sits on on top of the slide though. I'm sure I can pick that stuff up quite cheap.
Post by aeroxbud on Jun 21, 2020 18:10:00 GMT -5
Good score 👍
Post by matlock on Jun 21, 2020 21:12:49 GMT -5
yea maybe on ebay someone has the pieces for sale
Post by matlock on Jun 21, 2020 21:16:25 GMT -5
you know not for nothing but i think i remember a few weeks ago or so someone had a carb too big or something i believe it a delorto someone was trying to get it off them but i dont remember who it was maybe someone can chime in
Post by Kenho21 on Jun 21, 2020 22:19:47 GMT -5
So I took all of the jets/atomizers/needle out. I'm not super familiar with PHBG carbs, but I believe the 262AN atomizer is the correct one for 2T's. The 90 main says Polini on it, so someone was trying to tune it at some point. The float spring has no spring to it whatsoever though. I'm talking about the little springy plug thing that dangles from the float before you install it. Is it not supposed to compress at all? If it doesn't, it would seem like the float literally just floats but has no opposing force from the spring.
Post by ryan_ott on Jun 21, 2020 22:30:14 GMT -5
The slide also has a number on it. Treatland has all the parts you need. Save the trouble and get a “kit” of mains like Polini or Stage6 etc. I’ve found the mains from treatland to be inaccurate. The float just, well floats. No spring sometimes the float needle will have one just depending on which is installed.
Post by matlock on Jun 21, 2020 22:32:33 GMT -5
a pic would be helpful but i dont believe there is much spring tension needed because gravity pulls the float down when gas is low if i am correct
Post by Kenho21 on Jun 21, 2020 22:34:48 GMT -5
Okay, that make sense. Was just a little confused because every other carb I’ve ever taken apart has the springy float needle.
Does the needle in the slide get hold in place the same as the stock Mikuni style? With a little seat that rest on top of the needle, but under the spring?
Trying to figure out exactly what parts I’m missing.
I’ll pickup a kit from Treats.
Post by matlock on Jun 21, 2020 22:39:52 GMT -5
yes exactly but there is a plastic piece that sits at the bottom of needle that the cable locks into and it sits under the spring atleast on my 22mm delorto its that way
Post by matlock on Jun 21, 2020 22:41:21 GMT -5
Post by matlock on Jun 21, 2020 22:44:48 GMT -5
this should be all the part that are inside above is a link to what i believe is everything pictured
