Post by Kenho21 on Jun 21, 2020 22:50:44 GMT -5
Thank you.
Post by matlock on Jun 21, 2020 23:00:35 GMT -5
you got no problem you are welcome
Post by Lucass2T on Jun 22, 2020 8:08:50 GMT -5
Dellorto black racing. Looks genuine. Strip it and check every single part. Clean it thoroughly with brake cleaner and compressed air and yu should be good to go. Make sure that plastic float is still fully sealed. Also, if the main jet is an unmarked one, make sure to be certain the carb itself isn't some really well done clone after all.
Post by Kenho21 on Jun 22, 2020 8:17:06 GMT -5
Dellorto black racing. Looks genuine. Strip it and check every single part. Clean it thoroughly with brake cleaner and compressed air and yu should be good to go. Make sure that plastic float is still fully sealed. Also, if the main jet is an unmarked one, make sure to be certain the carb itself isn't some really well done clone after all. I've already taken all of the jets out and inspected it a few posts back. The machining and quality of everything feels pretty high quality, so I would guess it is real. The only thing that would seem suspect to me is that in the outlet side, where it connect to the reed valve intake, there is black factory paint on the inside of the outlet. I can take a pic later. I'll definitely give it a good once over before I put it on any of my bikes. Anyone know if an AF16/18 does well with PHBG carbs? I see everyone else running PWK and others for some reason.
Post by Lucass2T on Jun 22, 2020 8:19:15 GMT -5
Every small 2 stroke runs great on a PHBG. KTM uses them from the factory on their SX50 mini's. When you're in the range from 5 to 15hp these will work GREAT!
Post by Kenho21 on Jun 22, 2020 8:29:49 GMT -5
Awesome! I think I'm going to throw this on Dumpster Scooter once I get a kit for it.
Post by Kenho21 on Jun 22, 2020 8:49:52 GMT -5
So as far as picking up some jetting kits to get me started, should I just grab some main jets and pilot jets or is the needle kit and other stuff necessary too?
Post by aeroxbud on Jun 22, 2020 9:51:21 GMT -5
You can normally tune these pretty good without buying additional needles. See how it goes with just the jets first.
Post by matlock on Jun 22, 2020 11:48:05 GMT -5
Did you order the kit Kennny
Post by Kenho21 on Jun 22, 2020 15:16:30 GMT -5
Not yet, but I have a basket or Treats ready to pull the trigger on shortly.
Post by matlock on Jun 22, 2020 18:41:17 GMT -5
cool
Post by Mech Warrior on Jul 10, 2020 11:58:30 GMT -5
Ken how is the build coming along as of now?
