Post by bob007 on Jun 22, 2020 15:28:35 GMT -5
I have a 6 month old 150 gy6 Zenn scooter. It will not start. If I remove the electric choke and cover hole, it will start right up. I purchased a new automatic choke and it still will not start. If I again cover the choke hole with tape, it starts right up a runs fine.
What is the problem here? It is a Deni pd24j carb.
Again the scooter is only six months old.
Post by pinkscoot on Jun 22, 2020 15:50:16 GMT -5
(welcome2)It sounds like the idle is adjusted to lean and the small opening of the plunger isn't letting enough fuel in or you have 2 bad enrichers.
Post by bob007 on Jun 23, 2020 21:25:51 GMT -5
(welcome2)It sounds like the idle is adjusted to lean and the small opening of the plunger isn't letting enough fuel in or you have 2 bad enrichers. I installed a new automatic choke (enricher) and it made no difference. The mixture setting was set by the factory and I never touched it. Bob
Post by rocketdogiv on Jun 23, 2020 22:18:21 GMT -5
That's odd Bob. Have you checked the voltage to the enricher?
