Post by Zino on Jul 18, 2020 19:58:40 GMT -5
Stalls under acceleration . Jetting could be the fix . Do you have a selection of jets ? Do you run Open Filter or Stock air box Did you install a new carb ? Do you have a manual choke that we can use for tuning ?
Post by connorfixesstuff on Jul 21, 2020 19:40:32 GMT -5
I run a sport air filter I think. Also, I do not have a collection of jets. I replaced the carb too. The jets are clear, I checked.
Post by geoffh on Jul 22, 2020 14:36:47 GMT -5
You would be better off with a stock air box and a set of jets to get it tuned before you think about a 70 kit,a set of jets and a new air box under£30. Here's a kit I have, your carb needs all the air ways to be checked a cleaned not just the jets. Geoff
Post by connorfixesstuff on Aug 20, 2020 12:09:33 GMT -5
Old problem solved but new one came up...
I replaced the piston and cylinder with a 70cc big bore kit. I did a dry compression test, and it was at 150 psi. The problem is, it won’t start. I checked spark and it’s bright as day. I kicked it over with the spark plug in, and then pulled it out to examine. It had fuel on it.
Could oil be an issue? The scooter has an oil leak.
Post by geoffh on Aug 20, 2020 14:31:33 GMT -5
Old problem solved?share the solution please. 70 kit problem,were is the oil leaking from,have you upjeted for the 70 kit,did the arrow on the piston point to the exhaust when fitted.
