Post by Kick start on Jun 28, 2020 13:35:25 GMT -5
I believe I found a part off the oil catch can that i can use for a pressure sensor.
Post by Mech Warrior on Jul 10, 2020 9:29:00 GMT -5
I like that.
Post by taggeorge on Sept 30, 2020 19:53:47 GMT -5
Where would it screw into the engine that has oil pressure?
Post by GrumpyUnk on Oct 1, 2020 10:33:24 GMT -5
+ If this is for a 139QMB, the only way to access oil under pressure is via the tube/surround that flows oil to the rocker arm assembly. You may be able to access flow at the strainer, I have not looked. That is where coolers attach their fittings leading to the cooler radiator. The pump just pushes oil around the cylinder studs to an outlet up by the cam & followers. It is then whirled all over the place by the spinning cam and oscillating followers, hopefully lubricating the rockers and the cam bearings. Using splash, not pressure. May be missing something in this gizmo. tom
Post by golfmech on Oct 10, 2020 21:31:46 GMT -5
the screen is probably on the suction side of the pump so i don't think this will work
