Post by swiiper on Jun 28, 2020 17:22:58 GMT -5
Hello!
I'm from Finland and i'm going to say first that my English is crap so bear with me even if there is some grammar stuff wrong.
I have some strange clearance issues on my Keeway F-act 2010 gearbox\rear shaft. If i take clutch off shaft moves about 1cm or something and it eats my clutch fast. My Question for you motorgods is as follows. My scooter has copy horizontal minarelli engine and it doesn't have support bearing on the other end of the shaft, infact there is place for the bearing in case but the shaft doesn't have place for it. So, is genuine horizontal minarelli's rear shaft compatible with the copy minarelli? That would be so much more easy to get and only thing what has kept me from ordering one has been that i don't know is the measurements same. it cost something like 50euros here and i'm not ready to put that kind of money to it without knowing is it going to work. I've had bad luck finding the proper shaft here so i have every summer switched those bearings and tried to find that right kind of shaft. Also i'm starting my first crankshaf project today, i'm going to switch the original chinese made to something more sturdier so if i get somekind of tuning mood and want to put bigger bore cylinder in i have already crankshaft what supports the load.
Thank you if you can point me to right way and even if you cannot help with this. I'm going to read these forums and watch 49scoot.com youtube videos and maybe someday i'm even half as good as you pros
Sincerely Kimmo
Ps. This was my first post but i made it! YEY!
Sincerely Kimmo
