Post by ethan1738 on Jun 30, 2020 18:42:39 GMT -5
Hello my names Ethan and I have this key west TGB that I got for cheap, which I had to put a new carburetor filter on to get running but when I finally got it going at first it ran good when I had mixed gas and oil in. But now I only have regular gas in it, the oil is full, and the battery is charged but it won’t turn over completely and the oil light is on, so I’m not sure what to do to get her going. Any help and tips would be greatly appreciated Here’s the vin number if your looking for information RFCHA10437Y650783
Post by geoffh on Jul 1, 2020 15:15:47 GMT -5
It,s difficult to spot your problem,will it kick start?try the tech section for self help use the directory button on the left of this screen to find no start issues.keep on asking if you need to.
Post by aeroxbud on Jul 1, 2020 19:10:11 GMT -5
Welcome to the forum Ethan. I'm guessing it's a two stroke, as I'm not familiar with this scooter. The oil light just tells you the level in the tank. Check to make sure it's full. If you were mixing oil as well it of fouled your plug. Does the motor spin over if you try the kick start?
Post by Mech Warrior on Jul 10, 2020 19:36:16 GMT -5
Hello mission impossible Welcome to the Forum the serial number does nothing for us. Now a 1pe40qmb or 139qmb would be helpful. Well there can be several issues here one being possibly your oil level sensor is faulty. Next problem could be your battery may read charged but cannot handle a load , try jumping the battery see if she starts then.If it still wont turn over try taking out the plug and turning it then reinstall plug. Attempt to start again if still no go you may need a new starter. Try the kicks starter to see if she will run period.
