rt50
Post by rt50 on Jul 10, 2020 16:31:34 GMT -5
Sum 1 help me I need to up jet my adly rt50 but don't know what size thay shud be
Post by Mech Warrior on Jul 10, 2020 18:13:05 GMT -5
You need to go 10%-15% larger than what you originally had.
rt50
Post by rt50 on Jul 11, 2020 14:46:27 GMT -5
I know what size I need just don't know what size I need to get that fits my carb if get me
rt50
Post by rt50 on Jul 11, 2020 14:47:11 GMT -5
Post by Mech Warrior on Jul 11, 2020 15:32:31 GMT -5
Only you can answer your'e question sir as we do not know what you have. If you want help you need to include more information. like is it a mikuni carb? Mikuni carb jets are commonly M 6mm. Dellorto carbs seem to share the same size jets M6 thread as well sir.
Post by aeroxbud on Jul 11, 2020 16:37:45 GMT -5
There should be a brand on the carb. Then have a look at the thread to see how wide it is. Most are 5 or 6mm, so easy to tell even using a rule, or tape measure.
rt50
Post by rt50 on Jul 11, 2020 19:12:48 GMT -5
It's says nothing on carb my bike is a adly rt50 standerd carb
Post by ultrasuede on Jul 31, 2020 1:58:54 GMT -5
The stock carb is too small for what you want. You need to upgrade to a 21mm carb and a main jet in the realm of 70 - 92 depending on your intake and engine gremlins.
