Post by mrchilled85 on Jul 12, 2020 15:38:21 GMT -5
Hello anyone know the measure of the minarelli horizontal flywheel for fitting on the crankshaft as just removed the Ducati stater and flywheel off the malaguti f15 engine and want to go to the non ducati setup so it will work with my bike loom
just tryed the flywheel off my clone 1e40qmb but flywheel fits very loose and dont feel right
or if anyone can tell me the shaft size so i can check as i know on my clone 1e40qmb it has the 14-17mm for the flywheel
Post by Mech Warrior on Jul 12, 2020 22:02:59 GMT -5
Minarelli 50cc fly wheel dimensions Diameter: 101 mm Width: 38 mm Inside Diameter: 82 mm Fan 3 Bolt Hole Spacing: 42 mm Fan Bolt Thread Size: M 6x1.0 Mounting Hole Inner Diameter: Tapered hole 16.5mm at its largest/14mm at smallest
Post by Mech Warrior on Jul 12, 2020 22:03:15 GMT -5
Post by Mech Warrior on Jul 12, 2020 22:04:58 GMT -5
Post by Mech Warrior on Jul 12, 2020 22:07:47 GMT -5
Post by mrchilled85 on Jul 13, 2020 0:32:06 GMT -5
Post by Mech Warrior on Jul 13, 2020 8:19:45 GMT -5
No problem kind sir.
