jayrod427
Post by jayrod427 on Aug 3, 2020 12:08:45 GMT -5
That makes way more sense. I read a bunch of those in the tech section, but somehow missed that one. Thank you!
Post by Zino on Aug 3, 2020 16:55:38 GMT -5
Stick with stock till you have some power from pipe and or kit and then make a decision
For a daily build to cut down on wear and tear on belts . You run as light as contra as possible that prevents belt slip. Race builds you care less about belts and wear and tear since you replace stuff every race So you take as stiff a contra as possible so you get good downshifting for coming out of corners .
jayrod427
Post by jayrod427 on Aug 3, 2020 18:38:11 GMT -5
although this one is not quite a true plug chop it was after a 10 mile commute home from work stop light to stop light wot. Most lights about a mile apart. Last mile to Last turn then wot for about 1/4 mile and kill it. This plug has about 50-60 miles on it. Ring is 1.2mm Just a touch lean, 90 main currently. Don’t have a 92 or something. Might toss in 95 when the Yasuni shows up, and open up the air box a bit.
jayrod427
Post by jayrod427 on Aug 4, 2020 12:39:27 GMT -5
Naraku cylinder is on slight back order. Prob won't get it for a couple weeks, but the Yasuni shipped today so expect it early next week. Only downside to scootertuning.ca is freight time from Canada to US.
Last night I de-snorkeled the airbox, plugged the hole from the exhaust hose thing, and started venting the CVT cover. Yesterdays ride home noticed some rpm climb with mph drop. Letting that heat out def can't hurt anything, and I don't ever do any rainy riding or offroad. On a side note of being a bonehead when I initially changed the rollers the CVT cover gasket ripped, so I spent like $10 and got a new one. In hindsight don't even need that gasket since it's going to be vented now anyway. DOH!
I have found some oil leaking from behind the clutch so I'm guessing needs the axle seal or whatever it's called. It's definitely the final drive oil as I changed it the night before to get the right amount in, and it was a bit low as not much came out on top of being quite filthy. Used 85-140 as that's what the manual states even though I've seen the writeup recommending 80-90 or even 10-30 motor oil. Looks to be a fun time tearing the axle apart to get to that seal...... Might be good to inspect all those bearings and replace at that time.
Post by geoffh on Aug 4, 2020 14:42:27 GMT -5
Jayrod,don't,t be to hasty drilling that air box it should be OK for a 70 kit as it stands,I cannot remember any one changing gear box bearings unless they have lost the oil and cooked them.
jayrod427
Post by jayrod427 on Aug 4, 2020 14:56:59 GMT -5
Jayrod,don't,t be to hasty drilling that air box it should be OK for a 70 kit as it stands,I cannot remember any one changing gear box bearings unless they have lost the oil and cooked them. Geoff Ya i'm not going to do any more than the de-snorkeling. I'll inspect the bearings thoroughly when the seal replacement time comes. It was pretty lowon oil, and very dark and nasty. Prob never been changed in 4K miles. I bought the scooter years ago from a guy coming off a DUI, and rode it mainly at the track as a pit bike. Prob not even 100 miles. Then I sold it to a guy who tooled around the lake with it. Then I bought it back from him when he got a golf cart. I am currently on a mission to get it fixed up and all things right and/or better. After the performance/maintenance phase this winter I want to strip it down and paint/cleanup all the plastics.
Post by Zino on Aug 4, 2020 15:04:21 GMT -5
I have gasket scan for the gear case gasket. If you need it just let me know . My daughter grabbed a picture off the internet and I built my own.
Post by aeroxbud on Aug 4, 2020 17:41:48 GMT -5
You might be able to remove the seal the same way as a seal on the variator side. Drill a small hole, then pull It out with a wood screw. It would save taking the gearbox apart.
jayrod427
Post by jayrod427 on Aug 7, 2020 11:13:36 GMT -5
6mm jetsThis would be correct kit to get me some smaller increments? I'm not exactly sure what the carb is since PO replaced it with ebay special. But the 6mm jets I bought for it already work. I think currently I need a 92. 90 is a tiny fuzz lean even when it's hot out. I have a 95, but 92 and 97 would be nice once the pipe and bbk goes on.
Post by geoffh on Aug 7, 2020 14:57:08 GMT -5
Those jets go up 2 steps at a time so you will miss 97 ,you are also paying for that polini label,here's a kit of 10 jets I got in the UK £15,on eBay.
Geoff Picture to follow
Post by Zino on Aug 7, 2020 17:27:34 GMT -5
It is best to get a wide range of jets so you can tune it in . If you get jets from the same supplier you can buy a tighter range . This protects you from mis labeled or miscast jets from knock off suppliers . These are both mikuni jets labeled the same size but only one is genuine The holes nad angles of the jets were different one is genuine mikuni one is glixal I could make the glixal work because of the large range but a 90 did not flow like the other 90 .
Post by Zino on Aug 8, 2020 12:31:46 GMT -5
Nice looking vents that will help alot with cooling . Did you use a demel?
jayrod427
Post by jayrod427 on Aug 8, 2020 12:36:37 GMT -5
Ya just 2 in front and 3 in back helped nicely. Even just idle the variator fan, and even the clutch bell move air in and out. First I drilled holes, then some dotco work, then dremel and hand files to finish.
jayrod427
Post by jayrod427 on Aug 10, 2020 10:36:06 GMT -5
The Z is getting delivered today! Ordered an LED brake/tail light, turn signal bulbs, and brake light pulse module. Battery was dead after slow ride and goofing around Friday evening, and just want something brighter to get more attention. Hoping LED bulbs will help just a tiny bit more on the poor stator. It's been fine as long as wide open steady riding. Might also drop the tender on whenever I can remember.
edit: CHT gage came in sooner than expected. Looks like I'm logging some miles tonight!
