Post by aeroxbud on Sept 9, 2020 16:42:09 GMT -5
Each manufacturer is slightly different. But they are normally around 15%, 35%, and 50% more in tension. As they get stiffer.
jayrod427
Post by jayrod427 on Sept 9, 2020 16:45:11 GMT -5
Might do white with the swivel seat as well then.
Post by Zino on Sept 9, 2020 16:51:51 GMT -5
jayrod427
Post by jayrod427 on Oct 2, 2020 9:50:45 GMT -5
Pulled the trigger on a white Malossi contra, Malossi spring seat, Malossi x special belt, Polini 17 pwk/cp, main jet set, choke cable, single throttle cable conversion kit.
Next week when it all arrives I'll start with the contra, belt, and spring seat to see if that resolves the vibe/noise. Then after testing the drivetrain changes swap the carb and work on tuning, especially now with the weather changing anyways.
I went with 80-98 main jet set. Hope I don't regret it and have to get the 100-118.... Sucks being right on the borderline of jet size, but polini jets may respond differently than what's in there now.
jayrod427
Post by jayrod427 on Oct 8, 2020 20:42:50 GMT -5
Well the contra, contra seat, and belt did nothing for the vibration. Literally nothing changed....  Then after that ride I changed the rollers from 4.3 to 4 gram set. That made a nice difference. After the takeoff bog(might need a little more clutch spring, currently goes to about 6,000 out of the hole) then it runs to and hovers around 9,300 until about 50 then tops out full travel and climbs to 10,000 at 55+. Tomorrow/this weekend work on the carb, throttle cable, and choke setup.
jayrod427
Post by jayrod427 on Oct 8, 2020 22:53:15 GMT -5
Slight change of plans. Started putting the carb together, scootertuning must’ve decided I don’t need the main jet kit.......eeerrrgghhhhh! Twice now they’ve left something out. I’ll prob start swapping the throttle cable and routing/mounting the choke tho. Just won’t get it running this weekend.
Side note the needle will be a royal pita to tune. Getting the return spring and clip out to release the cable end to get the needle out is quite the need small fingers task.
jayrod427
Post by jayrod427 on Oct 9, 2020 12:53:09 GMT -5
Scootertuning is on the ball getting me the jet set quickly. Shipping out today FedEx rushed. I'll know later today if that means here tomorrow, or early next week.
They are very good at righting wrongs, and that goes a long ways. Mistakes happen.
jayrod427
Post by jayrod427 on Oct 12, 2020 19:51:21 GMT -5
Got the jets today! Got some tuning to do...... need to order a bigger pilot(38 now). Have to run only 1/2 out on the air screw or else idle hangs and off idle throttle stutters and hesitates. Need to richen needle clip(which is a major pita) as it hesitates and stutters part throttle almost to the point if you don’t go off throttle or wot it would prob die. Main jet too rich(started with 96) lost top speed, and only runs 270 on 2 mile blast.
Sucks to order pilot jet set as it’s so cheap and I don’t need anything else, and wait a week... had high hopes the 38 would be enough.
jayrod427
Post by jayrod427 on Oct 12, 2020 23:37:09 GMT -5
Going to 92 helped a bit, 315 or so, little better top end. 90 up next. Richen needle one clip helped. Doesn’t cut out now part throttle. Will heat up a bit cruising on needle tho. One more clip rich is the last position and will hopefully do the trick.
ingram
Post by ingram on Oct 26, 2020 13:24:57 GMT -5
Hey jayrod427 did you get your final jetting sorted out? I have a similar setup and just finished putting a Polini CP 17.5 on mine and currently trying to tune it. So far I have the stock 38 idle jet with needle at one clip rich and an 84 main jet but temps at WOT stay max 300 and I am not getting as high RPM and speed as stock carb so think I am still off. Started with 98 main and flooded my plug and have been going down from there but worried as 84 seems low compared to yours.
jayrod427
Post by jayrod427 on Oct 29, 2020 23:33:59 GMT -5
Hey jayrod427 did you get your final jetting sorted out? I have a similar setup and just finished putting a Polini CP 17.5 on mine and currently trying to tune it. So far I have the stock 38 idle jet with needle at one clip rich and an 84 main jet but temps at WOT stay max 300 and I am not getting as high RPM and speed as stock carb so think I am still off. Started with 98 main and flooded my plug and have been going down from there but worried as 84 seems low compared to yours. Unfortunately no. Cold snap here wrecked riding season for me. I’m not hardcore enough, or have the gear for the 30’s.
ingram
Post by ingram on Oct 30, 2020 15:05:56 GMT -5
Unfortunately no. Cold snap here wrecked riding season for me. I’m not hardcore enough, or have the gear for the 30’s. Ah ok understood. Well just FYI I finished tuning mine and ended up with an 82 main and 38 pilot at one clip rich on the needle.
