Variator
Aug 2, 2020 3:30:08 GMT -5
via mobile
Post by ApeShit70 on Aug 2, 2020 3:30:08 GMT -5
Soni got a Doppler variator. When I went to install it it is 2 small to fit on the crank? Is this because it has. 12mm gudgeon pin instead of a 10? And can I take it to a machinest and have the toothed hole opened? Well I hope that maybe it will work on the Italjet??
Post by aeroxbud on Aug 2, 2020 14:46:45 GMT -5
I think it is. Think it's not only the gudgeon pin that's bigger. The spine must be 16mm, instead of the usual 13mm.
Post by ApeShit70 on Aug 3, 2020 5:29:15 GMT -5
Must be because it's way smaller? So now either for the dragster or to a machine shop
