Post by cyburban on Aug 21, 2020 21:47:45 GMT -5
Post by geoffh on Aug 22, 2020 15:18:29 GMT -5
Yep I think your spot on that bit looks to be bent up and would stop it retracting,it all looks a bit chewed up,some delicate sanding might help.just check that the return spring is free at the carb end,you may have some wear issues at the handle to contend with,or it,s an operator error(we all get it wrong)keep asking.
Post by 808ministroke on Oct 6, 2020 13:19:34 GMT -5
I have had this issue before Try loosening the Screws holding the 2 pieces of the Assembly at the handlebar and see if that doesn't solve your problem.
Post by 808ministroke on Oct 6, 2020 13:19:44 GMT -5
