Post by blacky on Aug 23, 2020 2:36:06 GMT -5
I have a KYMCO DINK 150cc Is there any 49cc frame that would fit the 150cc GY6 engine? Or a similiar 49cc KYMCO model that would let me put this engine in? Just asking because I want 49cc documents with a 150cc engine
Post by FrankenMech on Aug 23, 2020 3:14:12 GMT -5
Welding mounts in would be required. The 150cc is top mount and the 49cc is bottom mount. Better to just keep the 150cc.
Post by CrankingWithCG on Aug 23, 2020 4:49:03 GMT -5
A method i thought of when my 150 got stolen. I had a 150 motor and a 50 frame. I took the 50 mount out, flipped it upside down, put an axle bolt through the ears on the top of the 150 motor and the two little legs on the 50 mount. Spaced it to where the motor and wheel were all centered....then we found my 150, and I left the project. My thinking was that you could get the longer (now top part) of the 50 mount spaced so it was snug in the frame, and drill holes in either side of the frame through to run a big section of threaded bar all the way through, put nuts on both sides of the frame to hold the bar through....possible bolt in engine swap? Dunno how much I'd trust a bolted through frame mount, but the amount of times ive seen welded in mounts break makes me think its a plausible alternative
