Post by Kenho21 on Aug 25, 2020 22:53:19 GMT -5
Killakeola and I will soon be make his Vespa ET2, Betty White (he gets credit for badass the name), fast. We want to make Betty White wicked fast. We are thinking of doing an aggressive air cooled build for now, with plans of going liquid cooled likely in the future. It's a Piaggio based 2T. I'm vaguely familiar with Piaggio and confident enough from my experience with Minas that I think we can make this a solid ripper to show up the Elite guys in Detroit.
Post by Kenho21 on Aug 25, 2020 22:54:46 GMT -5
Here's our plan and our hangup so far... Crank: rb.gy/n2xwc2Cylinder: rb.gy/5b8sawI know we need a spacer for the 85mm con-rod crank, but can anyone direct us to which spacer will work? I can't find one by Malossi.
df41590
Post by df41590 on Aug 25, 2020 23:20:13 GMT -5
Post by oldgeek on Aug 26, 2020 5:15:25 GMT -5
Don't forget a $350 pipe to go with that cylinder. And oh yeah, a carb, clutch and CVT to support it.
Great name for the build!
Post by Kenho21 on Aug 26, 2020 8:26:08 GMT -5
I am wondering the same thing. I see the Stage6 spacers, but there are two different versions, which makes me think one may work better than the other or they may not work at all. I’m not sure on which to buy.
Post by pinkscoot on Aug 26, 2020 9:00:48 GMT -5
df41590
Post by df41590 on Aug 26, 2020 10:00:09 GMT -5
I am wondering the same thing. I see the Stage6 spacers, but there are two different versions, which makes me think one may work better than the other or they may not work at all. I’m not sure on which to buy. Looks like the difference between the two is the S6-79140ET07 has a larger transfer port. I'd go with that one if you couldn't find a Malossi spacer.
df41590
Post by df41590 on Aug 26, 2020 10:12:59 GMT -5
Looks like multiple base gaskets come w/ both, scootertuning's pic they're hidden by the head and piston not laid out like on scooterpartsco, but definitely go w/ spc save some cash for other mods.
Post by Kenho21 on Aug 26, 2020 23:57:56 GMT -5
I’ll reach out to SPC and see what they have to say. Would be sweet if one of the kits comes with the spacers needed. Maybe I can get Scootertuning to price match...
Post by Killakeola on Sept 9, 2020 0:37:41 GMT -5
Parts ordered
Post by Kenho21 on Nov 15, 2020 14:05:51 GMT -5
Had an accident during disassembly last night, any suggestions?
Post by CrankingWithCG on Nov 15, 2020 15:06:28 GMT -5
Had an accident during disassembly last night, any suggestions? Reverse drill bit set
Post by captincvmn on Nov 15, 2020 16:32:56 GMT -5
Or if you have it available: Tig a nut onto the stud and backbit out with a wrench.
Best part of a scooter named Betty White: She’ll never die!!
Post by 90GTVert on Nov 15, 2020 16:35:05 GMT -5
Try the easiest thing first IMO. See if there's enough left to get a pair of vise grips on there tight and turn it out.
Post by milly on Nov 15, 2020 16:45:34 GMT -5
Also could heat the aluminum casing around the just before twisting it out as that expands quicker than steel from what I remember.
