Post by oldgeek on Nov 15, 2020 20:10:23 GMT -5
If you try the drill route carefully file a flat spot so you can punch mark exact center easier.
Anyone with a welder should be able to weld a nut to the busted stud fairly easily. The heat from welding will also help to loosen it up.
Post by Kenho21 on Nov 16, 2020 13:41:27 GMT -5
Thanks for the replies everyone.
We did try with a pair of vise grips, no luck. I was thinking of slotting it with a dremel and hitting it with a hand impact wrench. I think we’re gonna borrow a buddy’s welding machine and take it off that way though.
Post by captincvmn on Nov 17, 2020 12:24:44 GMT -5
If that doesn’t work buy an “EZ-out” set which has a left handed drill bit (runs in reverse) and spiral hardened bits that dig into the hole that’s drilled to remove the bolt/stud.
Post by CrankingWithCG on Nov 17, 2020 12:27:09 GMT -5
If that doesn’t work buy an “EZ-out” set which has a left handed drill bit (runs in reverse) and spiral hardened bits that dig into the hole that’s drilled to remove the bolt/stud. Ez out, thats what i meant 😂
Post by sevenninesandtens on Nov 19, 2020 17:51:47 GMT -5
my suggestion on how to make Betty White scream was going to be to chase her, but then I realized you weren't talking about chickens.....
one of my chickens names is Betty White Stripe.
Post by Kenho21 on Nov 19, 2020 22:37:09 GMT -5
I can honestly say I’ve never even considered how to make a chicken scream. Now I know.
Post by sevenninesandtens on Nov 20, 2020 8:21:33 GMT -5
I can honestly say I’ve never even considered how to make a chicken scream. Now I know. I never did before either, until my 2.5 yr old daughter decided to "race" the chickens.... chickens as it turns out do NOT like racing, poor ladies.
Post by Kenho21 on Nov 20, 2020 9:26:04 GMT -5
I can honestly say I’ve never even considered how to make a chicken scream. Now I know. I never did before either, until my 2.5 yr old daughter decided to "race" the chickens.... chickens as it turns out do NOT like racing, poor ladies. Hahaha that’s a good one!
Post by Steve B on Nov 20, 2020 12:43:09 GMT -5
Kenho21 Lmao, I love the name Bette White.
