Post by orangesoda123 on Aug 26, 2020 8:16:17 GMT -5
Hey Everyone!
I'm working on a 50cc Tao Tao knockoff (2006 Super Motor TP50QT). From what I can tell its basically identical to a Tao Tao of that generation in every way.
I'm at my wits end with this thing. It will start just fine and accelerate hard to about 8mph, but bogs really bad after that. It will eventually accelerate and I've gotten it up to about 38mph but it takes a while to get there.
Things I've done:
- 2 new carbs. The original was beyond repair so I bought a new one. It was bogging really bad with the new carb so I bought a replacement. Same Issue.
- Replaced Fuel Filter
- Replaced Spark Plug (the NGK I pulled out still looked near perfect)
- Replaced vacuum lines and y connector (It was leaking. If I hit with carb spray the engine would change rpm)
- Adjusted Valves (they weren't too far off)
Does anyone have any idea what I could try next? Next on my list is to bypass the fuel filter and go straight to the carb to see if its a fuel issue. Also might disconnect the belt drive to see if something there might holding it back. Maybe its the fuel "pump" itself? CDI? Trying not to just throw parts at the thing.
Thanks for your help everyone!!
Post by tortoise2 on Aug 26, 2020 10:29:07 GMT -5
might disconnect the belt drive to see if something there might holding it back If the engine revs up fine while rear wheel is elevated on the center stand . . the variator weights MAY not be oriented properly in the ramps?
Post by orangesoda123 on Aug 26, 2020 10:40:22 GMT -5
It does rev better on the stand, but still bogs regardless.
Post by tortoise2 on Aug 26, 2020 10:53:09 GMT -5
It does rev better on the stand, but still bogs regardless. Intake manifold vacuum leak is another potential gremlin.
Post by orangesoda123 on Aug 26, 2020 11:21:00 GMT -5
It does rev better on the stand, but still bogs regardless. Intake manifold vacuum leak is another potential gremlin. I can check this again, but when I spray carb spray around the intake it seems fine. I also replaced the intake and associated gaskets as they came with the new carb.
Petro
Post by Petro on Aug 26, 2020 12:54:02 GMT -5
Move the needle all the way down (clip on top, lean) and see if there is any difference. If not do the opposite (rich) and see if you get any improvement.
Post by orangesoda123 on Aug 26, 2020 15:52:43 GMT -5
Well I took the clutch/belt out and it seems to rev just fine without it.
Maybe something dragging in the drive line somewhere?
Post by orangesoda123 on Aug 26, 2020 15:54:18 GMT -5
Move the needle all the way down (clip on top, lean) and see if there is any difference. If not do the opposite (rich) and see if you get any improvement. What needle on top? Not sure I follow. Only adjustments I see are the idle screw and air/fuel mixture screw on the side
df41590
Post by df41590 on Aug 26, 2020 16:27:21 GMT -5
Check out this vid by partsforscooters. www.youtube.com/watch?v=jnQmM4vwJW0Just be aware some stock needles only have one notch so you may have to get a replacement adjustable needle.
Post by orangesoda123 on Aug 26, 2020 16:33:53 GMT -5
I see what you are getting at now. I can try to adjust this a bit. Could this cause the flatout bogging i'm seeing?
df41590
Post by df41590 on Aug 26, 2020 16:45:09 GMT -5
Well I took the clutch/belt out and it seems to rev just fine without it. Maybe something dragging in the drive line somewhere? Sorry just saw this part does the rear wheel/clutch and rear drive plates spin freely w/ the belt off?
df41590
Post by df41590 on Aug 26, 2020 16:46:16 GMT -5
I see what you are getting at now. I can try to adjust this a bit. Could this cause the flatout bogging i'm seeing? If it is running too rich/too lean yes. Check your plug now what does it look like?
Post by orangesoda123 on Aug 26, 2020 17:13:04 GMT -5
I see what you are getting at now. I can try to adjust this a bit. Could this cause the flatout bogging i'm seeing? I tried moving the clip to a few positions and no joy. Still bogs.
df41590
Post by df41590 on Aug 26, 2020 17:52:29 GMT -5
What does the plug look like? The replacement carb may have too big/too small of a main jet in it if you have the original carb you could try swapping MJ w/ the replacement if it fits.
Then you said that it reved up fine with the belt off, does the clutch and rear drive faces spin easily/quietly?
Post by orangesoda123 on Aug 27, 2020 8:36:50 GMT -5
What does the plug look like? The replacement carb may have too big/too small of a main jet in it if you have the original carb you could try swapping MJ w/ the replacement if it fits. Then you said that it reved up fine with the belt off, does the clutch and rear drive faces spin easily/quietly? I'll try and get the plug out today. The old carb MAY still be at the bottom of the garbage bin. It was in pretty bad shape.
