Post by NakedLeo on Aug 31, 2020 19:52:47 GMT -5
Post by Zino on Aug 31, 2020 21:18:25 GMT -5
Both are excellent kits . Very Big Upgrade over stock plenty of takeoff and a few miles per hour up top . Both are stock crank and stock carb friendly You might need a slight up jet carb adjustment . The stock powerbands are similar to stock just . So CVT may just need minor or no adjusting. Get the one that is in stock . Supplies are tight .
Post by NakedLeo on Sept 1, 2020 6:09:21 GMT -5
Alright will do Thanks for the help
Post by NakedLeo on Sept 1, 2020 6:12:51 GMT -5
One thing I’m not sure about is I don’t see any wristpin size
Post by Zino on Sept 1, 2020 6:47:53 GMT -5
Do you know what wrist pin you have ?
malossi comes in both 10 and 12mm in their kits polini some vendors will swap parts to allow for 10 or 12mm
Post by NakedLeo on Sept 1, 2020 11:59:47 GMT -5
i have not checked but im gonna do it tomorrow
Post by NakedLeo on Sept 1, 2020 23:19:44 GMT -5
ok so i am trying to find a kit for my scooter on this website www.pmtuning.co.uk/ but they dont include anywhere what size wrist pin there comes with the kit, could maybe one of you check on the website and tell me if i am missing something and if you find the wrist pin size add the link in your reply with both a link to a 10mm kit and a 12mm kit:) sorry if i am asking for to much but i really dont wanna buy the wrong kit either polini or malossi
Post by aeroxbud on Sept 2, 2020 6:03:49 GMT -5
Post by NakedLeo on Sept 2, 2020 9:55:59 GMT -5
Thansk for the links
I am trying to check the wristpin size but I can’t get the pin out of the piston head I have already removed both the metal clips or whatever they are called
Can someone tell me why they are not coming out
Never mind I got it, just used a bolt with a flathead screwdriver head and slammed on it with a hammer and it worked maybe not the safest way but pretty easy
Post by NakedLeo on Sept 2, 2020 10:27:53 GMT -5
So after checking on the wrist pin this is the kit im going to buy www.pedparts.co.uk/product/1404/malossi-70cc-sport-kit-10mm-minarelli-ac i am going to buy it on this website but i saw someone tell me i maybe needed to do some slight upjetting on the carb but i have no idea wich jets and so on i should get, im gonna add some pictures here of the carb and hopefully one of you can help me
And do i need to buy a better performance air filter or will the one i have on work
Post by aeroxbud on Sept 2, 2020 11:32:21 GMT -5
Your filter will be fine. You need to open the carb. The four screws on the bottom. In the middle, there will be a brass jet with a number on it. That will tell you what jets to buy.
Post by aeroxbud on Sept 2, 2020 11:42:38 GMT -5
You will need to order a new wrist pin bearing with that kit too.
Post by NakedLeo on Sept 2, 2020 12:05:28 GMT -5
Post by aeroxbud on Sept 2, 2020 13:45:05 GMT -5
Post by NakedLeo on Sept 2, 2020 14:26:30 GMT -5
im gonna measure the jets and check but is there a noticeable difference from the pin bearing that i linked and the polini one because i had already ordered the kit and the bearing when i saw it
