Post by NakedLeo on Sept 3, 2020 18:43:03 GMT -5
alright
Post by NakedLeo on Sept 20, 2020 20:31:32 GMT -5
hey so im looking into buying some lighter rollers,stiffer clutch springs and the other little springs inside the clutch any specific ones yall recommend
Post by aeroxbud on Sept 21, 2020 5:06:23 GMT -5
The small springs are clutch springs. Just buy a pack of three. Then you can fine tune it. There are other ways to fit them. But I would buy a spring puller. Especially for the stiffer springs. Contra springs you really want to lightest you can, and not get clutch slip. On most sports builds, the one up from standard is sufficient.
Post by NakedLeo on Sept 21, 2020 15:15:19 GMT -5
thanks for the info but what about the rollers ?
Post by aeroxbud on Sept 21, 2020 15:38:18 GMT -5
If you are running the standard pipe. The rollers might be ok.
Post by Zino on Sept 22, 2020 19:37:51 GMT -5
Weigh the rollers you have . And measure them for size they are either 15 x 12 or 16 x 13 mm. When I swapped the malossi cylinder The stock weight and stock clutch springs and contra worked fine . A 1/2 gram lighter on each weight and one notch up on springs was a a notch better .
As you upgrade to a pipe you tend to go lower in weight and need stiffer springs Other wise it will feel real doggy . The more extreme pipe the lighter the rollers and the stiffer springs needed
