Post by scooterpimp on Oct 16, 2014 4:55:18 GMT -5
Motoseal is the shanizzle to my wizzle. = good sealer .
Post by jhobe6678 on Oct 16, 2014 6:06:31 GMT -5
Damn. I just bought 4 different products from Permatex, how many do I need! LOL!
This section is great, at least I know what to get for my arsenal of disaster.
Post by toslowtogo on Oct 16, 2014 13:33:46 GMT -5
Post by FrankenMech on Nov 4, 2014 13:41:43 GMT -5
CRC Power Lube Ace Lube-E WD-40 for water & moisture remover. LPS-1 Greaseless lubricant Permatex Aviation Form a Gasket, hot oil and fuel proof. -Great stuff! EP Moly chassis lube grease Carb cleaner Brake cleaner Goof Off solvent Permatex Anti Seize Loctite green penetrating grade (do not use on small fasteners) Loctite blue threadlocker, the HF brand seems to work Loctite Red threadlocker, the HF brand seems to work Loctite Stick'n Seal Ultra universal adhesive Automotive Goop, same as Shoe Goo Electric contact cleaner Hi-temp RTV PB Blaster Rustoleum Appliance Epoxy paint High-Tack gasket spray adhesive
Post by jhobe6678 on Nov 4, 2014 21:14:10 GMT -5
CRC Power Lube Ace Lube-E WD-40 for water & moisture remover. LPS-1 Greaseless lubricant Permatex Aviation Form a Gasket, hot oil and fuel proof. -Great stuff! EP Moly chassis lube grease Carb cleaner Brake cleaner Goof Off solvent Permatex Anti Seize Loctite green penetrating grade (do not use on small fasteners) Loctite blue threadlocker, the HF brand seems to work Loctite Red threadlocker, the HF brand seems to work Loctite Stick'n Seal Ultra universal adhesive Automotive Goop, same as Shoe Goo Electric contact cleaner Hi-temp RTV PB Blaster Rustoleum Appliance Epoxy paint High-Tack gasket spray adhesive Whatever you do, don't light a match within 500 feet of your house.
Post by FrankenMech on Nov 4, 2014 22:55:43 GMT -5
Hey, that does not even count my scoot refueling station with the electric pump, O/A torch, propane torches, generator gas can, lawnmower gas can, camp lantern fuel, oil and lube supplies for various vehicles and equipment, the vehicles etc themselves, or a few dozen more aerosol cans, insecticides, herbicides, fertilizer, etc. There are quite a number of other adhesives including a about 1.5 gallons of epoxy. Then there is the plywood, sheet goods, dimensional lumber, scraps, electrical wire, etc. None of them come anywhere even remotely close to my chemical exposure from work.
Look around in your own homes and shops... :warning:
Post by defenestrate on Nov 23, 2014 20:28:34 GMT -5
Brake Cleaner : It's a strong cleaner that will remove all sorts of stuff, including things you don't want to remove so be careful around paint and coatings. It can dry out plastics and make them brittle too. I use it for cleaning engine parts, transmission parts, brakes obviously, and cleaning carbs (I use carb cleaner for carbs if I have it, but I tend to buy brake cleaner by the case.) It will work in place of starting fluid or carb cleaner to help out with no-start conditions at times too, but it tends to have a strong odor if the engine does start. It is worth noting that most brake cleaner these days does not contain Chlorine (it will say on the can if it does not, if it doesn't mention it, it likely does contain it) and as such is much easier on paint and most polymers than it once was. It actually works decently for cleaning electronics now as the non-chlorinated version won't eat the paint off of chips or dissolve anything else common to circuit boards. Also evaporates pretty quickly.
Post by oldgeek on Mar 29, 2019 17:48:48 GMT -5
Found this stuff a couple years ago, it works great for air box mods and connections. It is very similar to the stuff you find on some stock air box connections. Kinda like shoe goo.
Post by SMALL CC TEK on Mar 29, 2019 20:16:17 GMT -5
Kal Guard 30-30 lube no solvents in it Kal Guard contact cleaner Pvc pipe cement : Use this like loctite blue a ton of Japan bikes use this same with Taiwan bikes Amsoil Mp hD metal protector Dawn: dish soap awesome for anything dirty hands etc sonic cleaner etc Any brake cleaner on sale WD 40 must have a dry lube Sta-Bil fuel stabilizer Amsoil synthetic polymeric off road grease Lucas green synthetic grease Amosil high temp synthetic grease Marvel Mystery oil : A must have for any shop oil can ! lol Meguiars Plastic polish : Awesome for plastic head light lens or helmet shield Simi chrome metal polish Blue Magic metal polish Loctite marine Epoxy two part self mix 3M Ultra Pro silicone 08672 permatex Blue RTV silicone 6B LPS epoxy putty
And a few others !
Post by 2stroked on Apr 7, 2019 11:33:21 GMT -5
Found this stuff a couple years ago, it works great for air box mods and connections. It is very similar to the stuff you find on some stock air box connections. Kinda like shoe goo. They sell this at the Dollar General for like $3. Its surprisingly strong too. Last summer was halfway through mowing the garden area down, and the head gasket on the bushhog mower let go. I didn't have another, it was 8pm on a Saturday night and I was desperate to finish. I tossed through the tool boxes and junk drawers, and four d a tube of this. Figured why not, and just glued the head to the block using a copious amount of it. I just started the old bush high this morning. Still doesn't have a head gasket and I'm not even inclined to order one too this stuff lets go. I came here to post this stuff, But was happy to see it already here. This stuff is all great for screws or fasteners that bolt to small parts in odd places. Put the fastener into the part, add a tiny drop if this, and the screw is there forever. It will easily break free when you start to tighten it, but won't fall out during positioning.
Post by jstich on Apr 27, 2019 22:27:45 GMT -5
Im simple;valvoline oil and gear lube, blue loctite, stabil,jb weld,dot4 brake fluid,dish soap,etc. I think 2 strokers need more than 4t.
