70cc extreme 1e40qmb chinarelli budget build
Sept 4, 2020 8:36:09 GMT -5
via mobile
90GTVert, 190mech, and 5 more like this
Post by lokstar on Sept 4, 2020 8:36:09 GMT -5
Hey guys, been lurking here all the way from Australia for years now and picked up a wealth of knowledge. So thank you all for your freely shared info.
I slapped a Chinese 70cc kit (as it came/ untouched) on a 1e40qmb with a little cvt tuning a few years ago for a mate and 6500km later it’s still going strong regularly used for 80kph, 30-40 min rides.
I’m now planning new build on another scoot of the same model.
Below is my plan/recipe/parts list (most of which I already have) and I’m pretty handy with the tools, carb/cvt tuning and have decent selection of machining equipment so nothing within reason is out of the question.
The main goal of this build is making the most out of the cheapest accessible parts with NO performance brand name parts! for high revs and short runs, rideability and longevity are not of concern.
Any educated advice or experienced feed back would be appreciated.
Thanks👍
- Model: vmoto monza 1e40qmb (stock crank with 12mm wrist pin)
- Chinese 47mm 70cc AC cylinder
- 1.6mm cylinder spacer (1x .9mm automotive sheet metal spacer + 2x compressed gaskets) to bump durations of big bore cylinder from 178/118 (No gasket was used to measure that) to approximately 189/130
- Machine down the cylinder top/deck in my mill to rectify piston/deck height.
- Re shape/widened ex port to 72% of bore with a flatter/wider ex roof (not flat!) for more blow down area.
- All ports cleaned up/chamfer filed
- Ex and Trans port floor heights will be left untouched (as I don’t have a 90* Dremel attachment
- recut the stock head on my lathe to match bore and piston crown (for a proper squish band around 50% of bore)
- .5-.7mm squish (10-15% of bore)
- cc’d head (aiming for around 175psi of cranking compression)
- port match cases to cylinder
- JB weld and trench cases for high rpm flow (also shave cylinder skirts and piston ports for improved flow)
- Chinese copy 5mb reed cage for better flow angle and more intake area (this requires the cases to be milled 1.4mm each half/side for the cage to fit and cage mounting holes slotted to match case bolt holes)
- 5mm reed cage spacer
- Chinese carbon fibre reeds
- Chinese copy 5mb intake manifold
- Chinese copy 19mm Phbg Dellorto carb (however I may use a 21)
- stock derestricted airbox
- stock Ignition with stator plate slotted to advance timing (20-25* at 2k rpm depending on CHT’s and detonation)
- stock flywheel significantly lightened on my lathe.
- br9es plug
- trailtech tacho/CHT gauge
- Chinese expansion chamber (the specs of this pipe are slightly shorter and fatter but as close as you’ll get to the measurements I took from a mates S6 pro rep on his Aerox so it should match my port durations reasonably well.
- Chinese over range variator with a recut fixed half for better acceleration (I have 4, 5, 6 and 7g rollers to work with)
- Stock belt
- Stock torque driver with filed grooves for more travel
- Chinese 2k rpm contra (it’s the only one I’ve got laying around)
- lighted clutch with stock springs (My previous attempt at this was successful, engaging around 5.5k rpm
- Stock clutch bell
I don’t think I’ve forgotten anything there 🤔
All that said and done I’ve only spent $320AUD
Thanks👍
- br9es plug
- Stock belt
- Stock clutch bell
