Post by catadavidv on Sept 6, 2020 20:51:50 GMT -5
Got this new scooter BAOTIAN BT49QT-20c -2014 first time I am a complete newbie , it has a separate oil tank above the engine , thats just for the oil fuel mixture? And the engine oil has to be changed separately ? Its a 2 stroke engine, can I use the same 2Stroke engine oil for both mixture /engine ( if there are separate ) ? Thank you all in advance.
df41590
Post by df41590 on Sept 6, 2020 22:01:36 GMT -5
On 2 strokes there is no "oil change" like in a 4 stroke automobile/motorcycle/scooter where you unscrew a plug to change the oil in the engine. Don't worry on my first 2 stroke (snow blower) I thought I needed to do an oil change too.That plastic tank is where straight 2 stroke oil goes(no gas goes in that tank). It has an injector pump that pumps the oil from that tank to the carburetor to mix with the fuel.
Post by aeroxbud on Sept 7, 2020 8:56:14 GMT -5
The only oil that you would need to change is in the gearbox. It's very easy to do.
Post by catadavidv on Sept 7, 2020 9:47:16 GMT -5
Thank you guys you are awesome.
Post by aeroxbud on Sept 7, 2020 10:18:50 GMT -5
Just remember to top up the two stroke oil. If it runs out, your engine will die. Use the best oil you can. It really does make a difference.
