Post by captincvmn on Sept 19, 2020 19:35:32 GMT -5
Now that I have my little carb from VMC I took it apart to see what the main jet size is so I can get some to play with. Of course no numbers on it and although I’ve seen a set of gauges to check hole size I do not have any. The outside of the threads are 5.86mm. Would this be a 6mm jet body?
Post by captincvmn on Sept 19, 2020 19:36:09 GMT -5
Post by wiscootsin on Sept 19, 2020 19:46:47 GMT -5
Yes 6mm
Post by aeroxbud on Sept 20, 2020 15:56:48 GMT -5
Defiantly 6mm. If you ever measure a threaded bolt. It is always a little under the size.
Post by Lucass2T on Sept 22, 2020 11:30:39 GMT -5
Thats a Teikei (TK) carb I can see it from the float bowl in the back. Those take the big dellorto jets which are indeed 6mm.
