Coddas
Post by Coddas on Sept 23, 2020 8:28:06 GMT -5
Hello! I have a early 2000 Piaggio NRG mc3 purejet that wont idle or run . it starts up nice and sometimes if im fast i can even ride it 10-20 meters before it dies . But most times it just start up and idle for a few seconds . Anyone know what that can be ? Thinking on put a carb on soon
Post by oldgeek on Sept 23, 2020 9:11:26 GMT -5
Try giving the carb a through cleaning and check that your fuel flow from the tank is good.
Post by aeroxbud on Sept 23, 2020 9:49:14 GMT -5
It's injected. π€ Could quite possibly be an air leak of some kind. Check all the manifolds and seals for cracks, or leaks.
Post by pinkscoot on Sept 23, 2020 15:59:16 GMT -5
What kind of shape is the fuel pump? If it's like the later Purejets they have a contact problem in the pump. If its the same as the later ones the fuel filter has a vent on it because the pump pulls fuel at a high pressure and the normal gravity can't keep up. This is a picture of the filter. Here is a video of the fuel pump repair so you can see if you have the same one:
Post by aeroxbud on Sept 23, 2020 18:07:00 GMT -5
There is a manual in the tech section for your scooter. Click on the tab on the left.
Coddas
Post by Coddas on Sept 23, 2020 21:32:58 GMT -5
What kind of shape is the fuel pump? If it's like the later Purejets they have a contact problem in the pump. If its the same as the later ones the fuel filter has a vent on it because the pump pulls fuel at a high pressure and the normal gravity can't keep up. This is a picture of the filter. Here is a video of the fuel pump repair so you can see if you have the same one: I dont think is the fuelpump , i can hear it every time i turn the key , Funny there is a fuelfilter when a scootershop (piaggio seller) told me it dont have any filter But i will look on it There is a manual in the tech section for your scooter. Click on the tab on the left. Nice! Mine is generation before that one but the troubleshooting/injection part cant be much different
Coddas
Post by Coddas on Sept 25, 2020 13:49:36 GMT -5
I got a carb engine for it today if i dont get her running
