Post by darkbladeddeath on Sept 23, 2020 14:13:22 GMT -5
So I got it fixed nice and running pretty fast.
But I have gear oil leaking out somewhere else besides the drain plug and the filler plug. I can't find a good diagram to try and figure it out for myself. I'm not sure if it's overflow releasing because I maybe put too much in, or if it's coming out of a seal that I need to replace
Post by darkbladeddeath on Sept 23, 2020 14:27:59 GMT -5
After I let it cool I turned the wheel at the rear a little bit and I see an overflow tube that is wet on the bottom exit point of it. I may have answered my own question
Post by aeroxbud on Sept 23, 2020 17:14:07 GMT -5
They are not like a car where you fill it up, till it comes out. You need to put in a specific amount. Normally it tells you how much by the filler.
Post by Steve B on Sept 23, 2020 17:18:45 GMT -5
After I let it cool I turned the wheel at the rear a little bit and I see an overflow tube that is wet on the bottom exit point of it. I may have answered my own question Its not a overflow tube. It is a breather tube for windage.
Post by darkbladeddeath on Sept 30, 2020 14:04:01 GMT -5
So would it be possible that the fluid is coming out of there accidentally because of my overfill issue?
Post by Steve B on Sept 30, 2020 18:09:58 GMT -5
yes it's possible, but should never be happening unless you waaaaay over filled you're gear oil.
