loosegrit
Too much work. Hope for another scooter run Oct 2015.
Post by loosegrit on Oct 15, 2011 23:25:58 GMT -5
I would like too take the 2 spare wheels and mount them on front where the headlamps are now and put new headlights on the mirror extenion bar. I have no welding ability, would like to piece of 3/8" all thead in the cross bar behind the front panel. Think this is possible, will be trying something this coming weekend.
loosegrit
Post by loosegrit on Oct 16, 2011 18:25:20 GMT -5
Spare wheels for scamping. I am working on a cover for these.
Post by speedy1125 on Oct 16, 2011 18:33:43 GMT -5
can you take a photo of them removed? so we can see how you did the mount?
loosegrit
Post by loosegrit on Oct 16, 2011 19:21:31 GMT -5
2 - 1/2-13 x 12" althread, drilled 1/2'' holes in the cross support and used standard 1/2" washers & nuts to attached. Simple but seem to work. Next step is to take a large alumium sause pan and lid. Cut the pan down to cover the tires and use the lid as a base.
Post by Fox on Oct 16, 2011 19:47:35 GMT -5
I think that both sides of the bracket are going to bend in a twisting fashion and the plastic tabs are going to break.
I think you are asking for trouble having the electrical even more exposed to the wind and weather.
Post by stepthrutuner on Oct 16, 2011 19:50:08 GMT -5
Wow. Two spares for scamping? I must say you go prepared. Is there a problem with bears biting through tires while you sleep at night? I suppose you must have an aversion to plugging or Sliming maybe? Or the roads you travel must have some really mean, sharp tire-shreading rocks. Have you thought about mounting a headlight to the cover you are putting over the tires? If you plan on a mirror mount I would suggest tying the stalks together with some kind of bar on which to mount the headlight.
Post by jmkjr72 on Oct 16, 2011 19:55:59 GMT -5
i would tie the mounts into that lower part of that cross member too
you could always make a mount that goes acoss the threaded rod for the headlight but if you do go with the mirror mount you will want to tie the lights together and to another point on the bars to keep them steady
Post by 90GTVert on Oct 16, 2011 20:33:27 GMT -5
Wow. Two spares for scamping? I must say you go prepared. It's harder to notice in these pics, but in past posts he has revealed that he has one whole wheel/tire assembly for front and rear so all he'd have to do is replace it for a quick roadside repair. I think it's a pretty cool idea.
Post by stepthrutuner on Oct 16, 2011 21:14:42 GMT -5
I think that both sides of the bracket are going to bend in a twisting fashion and the plastic tabs are going to break. I think you are asking for trouble having the electrical even more exposed to the wind and weather. The tires resting against the front of the scoot will take the twisting force from the bar but a doubling of the thickness there wouldn't be a bad idea.
loosegrit
Post by loosegrit on Oct 17, 2011 5:29:12 GMT -5
My mirror extension is a 36'' x 2'' x 1/8 peice of alumium mounted above the handle bars. It holds the mirror, shield and headlights. The 18'' ID sause pan lid will give the extra support. But this is a learn as you go project. Thank You for your thoughts they keep thinking of the possiblities.
Post by bigkahuna427 on Oct 17, 2011 6:13:02 GMT -5
What you have attached that to is designed to handle the weight of the ABS plastic panels. It really wouldn't be very expensive to have a welder fabricate some brackets that would attach to the frame.
loosegrit
Post by loosegrit on Oct 17, 2011 12:55:49 GMT -5
When I put the pan lid for the base I will put additional bracing. In referance to slim, I don't leave home without but it never to be my only option.
When I leave Las Vegas Valley I am really in the desert, alone and on a horse with no name.
loosegrit
Post by loosegrit on Nov 27, 2011 0:41:41 GMT -5
