jayrod427
Post by jayrod427 on Oct 9, 2020 9:06:11 GMT -5
Anyone running one of these? I just got the 17.5 and working on installing and converting for it. How do the jets compare to stock? Right now ebay replacement carb I'm running a 100 main jet. Curious the comparable jet for the Polini. It comes with an 80/38. I ordered the 80-98 jet kit and am hoping somewhere in there will suffice. Any idea a good starting jet, or just throw in the 98 and work from there?
P.S. any tricks to getting the throttle return spring and cable out when needing to tweak the needle clip? Boy that thing is a peach.
jayrod427
Post by jayrod427 on Oct 9, 2020 11:10:57 GMT -5
Also does anyone have any tasteful recommendations for mounting the choke pull knob? Preferably with the cable hidden.
Post by Zino on Oct 9, 2020 21:01:11 GMT -5
I mount the long cable next to the key . The short cable I have just mounted to one of the cvt bolts on the top of the trans case
jayrod427
Post by jayrod427 on Oct 9, 2020 22:22:12 GMT -5
I mount the long cable next to the key . The short cable I have just mounted to one of the cvt bolts on the top of the trans case i was eyeing the exact same spot. Have to make a new cable out of the old throttle cable. The one supplied nowhere near long enough. Recycling. Lol.
