0weng
Post by 0weng on Oct 12, 2020 21:08:37 GMT -5
Hi Guys
Question about copper spray gasket. Can i use this alone on a cylinder head with out any actual gasket? My issue is my squish is quite high even with the thinnest gasket I have. The only way for me to achieve the squish i want (between 0.9mm to 1.1mm) is to get rid of the head gasket. I wonder if any of you have tried it on your build with out any leaking issues.
I have the athena 70 sport basic.
Thanks
Post by oldgeek on Oct 12, 2020 21:36:21 GMT -5
Works Great!
Post by Zino on Oct 13, 2020 7:09:22 GMT -5
It works great It was the only way I could get my Squish below 1 with that same kit .
0weng
Post by 0weng on Oct 13, 2020 9:28:41 GMT -5
What squish did ypu end up with? Couldnt find any recommended squish info online for this kit.
Post by nikola11 on Oct 13, 2020 10:08:18 GMT -5
If you have the AC version then the squish should be 0,9mm. That is what is written in the user manual for the Athena 70cc AC sport kit.
Post by Zino on Oct 13, 2020 19:28:40 GMT -5
.9 is in the instructions for the athena kit I got to .92 mm with transfers lining with piston at bdc with paper gasket This way you max out potential of filling up and clearing out the cylinder i
0weng
Post by 0weng on Oct 14, 2020 12:13:57 GMT -5
I just end up going to the machine shop at ask them to remove .4mm off the top of the cylinder and now i am at .85mm squish. Jut felt slight increase on acceleration. My top speed still seats at 111kph(69.3mph) just 1mph shy of my target top speed. I also adjusted my timing around 10* more advance which help a bit. I was at 107kph before all the mods.
Post by Zino on Oct 14, 2020 18:16:28 GMT -5
111 kph is impressive post up your scooter and your mods over stock in a build thread or signature thread a lot of us may learn from your build
