pewpew
Post by pewpew on Oct 14, 2020 11:44:08 GMT -5
Hello, i currently have a ported 86cc tpr cylinder kit with a 2fast 86cc exhaust and 28mm carburetor. I would like to get some more power and use the current exhaust and carburetor. I was thinking of buying the Bidalot RF88WR cylinderkit, does anyone have experience with bidalot cylinders? And is there any other cylinders like that for the same money? I would like to keep the stock cases because i dont think that the minarelli parts fit the malossi cases.
pewpew
Post by pewpew on Oct 14, 2020 11:45:59 GMT -5
pewpew
Post by pewpew on Oct 16, 2020 19:32:39 GMT -5
Im going to order the bidalot kit tomorrow if no one has better suggestions
Post by 190mech on Oct 16, 2020 20:45:07 GMT -5
It uses a 13mm piston pin,order a crank too!
pewpew
Post by pewpew on Oct 17, 2020 7:58:41 GMT -5
It uses a 13mm piston pin,order a crank too! Im buying a kit, it comes with a crank too. 500€ for the cylinder and crank kit
pewpew
Post by pewpew on Oct 20, 2020 13:23:23 GMT -5
What malossi contra springs should i buy with the bidalot kit? I had the malossi red +40% spring on the tpr kit but after warming up it took a few seconds to take off. I dont know if the contra spring caused it or not. Does the piaggio springs fit the malossi overrange la furia rossa kit?
