Post by leytondio on Oct 23, 2020 20:30:43 GMT -5
Hello all! Nice to join your forum.
I have a '96 Honda Dio (Canadian Spec), and recently purchased a RuckHouse Lowdown for Dio. I get to installing it and come to notice it doesn't clear my fender liner (under the seat, plastic rectangle). No big deal, I trimmed it to fit.
But the issues persist. The collar/ spring rub on my tire. It is a 3-10 Michelin something or other.
So I checked the website out and it seems it is literally just the Ruckus product.
So, do I try a 2.5-10 tire? I have added some pre-load to the spring to bring the collars up, and turned the bottom down an inch or so to compensate. It is very stiff, so with an inch of clearance I should be able to ride it without destroying my tire.
But then its not low... The reason for the purchase haha.
Does anyone have any ideas?
Post by geoffh on Oct 24, 2020 8:04:26 GMT -5
Hi and welcome to the forum,that's a real technical question your asking with "sketchy" info,some pictures might help,there,s lot,s of help available here but you need yourself with detailing your problem.
harleyracer59
Scoot Veteran
I'd rather be lucky than good. Good takes practice lucky just happens
Post by harleyracer59 on Oct 24, 2020 14:37:00 GMT -5
thats a pretty wide diameter shock. you can try a washer or 3 behind the top mount as spacers to move the shock outwards a little. cant go too much though.you need the nut to thread on sufficiently. and not interfere with the side panel. you can also put a spacer on the rear axle behind the wheel hub. or a combo of both. since you cant go too much on both. that or gat a chock that isnt so big round.
