0weng
Post by 0weng on Oct 25, 2020 13:28:48 GMT -5
Alright so I am in the last bit of my h20 build shopping. I need an some input onto which pipe should i go with. I ordered the TPR cylinder/crank kit and 30mm pwk polini. I am now looking into finding the best match for this kit. I am torn between the Big evo 84/94 pipe vs the MHR 77/86 bug bore pipe. The big evoh however, states that it can only be used on their 84/94cc cylinder kit. I wonder if thus pipe is tuneable to the tpr kit.
Post by aeroxbud on Oct 25, 2020 14:11:41 GMT -5
I think they can only be used on their kits because it has three mounting points onto the cylinder. Most only have two. If you know a good welder you could make a normal exhaust flange to fit.
0weng
Post by 0weng on Oct 25, 2020 14:21:27 GMT -5
Good point! Any other pipes thatvyou could recommend Just looking for more options
Post by 190mech on Oct 25, 2020 15:29:51 GMT -5
Post by aeroxbud on Oct 25, 2020 17:11:31 GMT -5
Go with this. ⬆⬆⬆
0weng
Post by 0weng on Oct 26, 2020 15:36:00 GMT -5
pewpew
Post by pewpew on Oct 26, 2020 19:40:35 GMT -5
The most pipe is probably one of the best ones out there
Post by 190mech on Oct 27, 2020 0:04:32 GMT -5
Had a member here(PIG) run one on his 95 S6 R/T for a while,then switched to a S6 R1400..The 95 is a different animal though...
0weng
Post by 0weng on Oct 27, 2020 17:59:58 GMT -5
The most pipe is probably one of the best ones out there I couldnt find any videos about it. I just want to see and hear it in action hence this pipe is not cheap
