Post by rocketdogiv on Nov 18, 2020 20:43:15 GMT -5
A 28mm PWK is too much Carb for a minor 5cc increase. Carbs, like a PWK, are very particular about the C.F.M. passing through the venturi. You'd be happier jetting the 24mm CV that came with it.
Post by CrankingWithCG on Nov 19, 2020 5:54:51 GMT -5
A 28mm PWK is too much Carb for a minor 5cc increase. Carbs, like a PWK, are very particular about the C.F.M. passing through the venturi. You'd be happier jetting the 24mm CV that came with it. I honestly thought about either a 26mm cv, or a 24mm pwk. I do think its just too big. Im having to jet so lean that it ends up running like crap down low
Post by CrankingWithCG on Nov 19, 2020 6:01:44 GMT -5
A 28mm PWK is too much Carb for a minor 5cc increase. Carbs, like a PWK, are very particular about the C.F.M. passing through the venturi. You'd be happier jetting the 24mm CV that came with it. Like, ive seen people use 26 slides on 125 pitbikes, but i feel thats even too big. If im going slide, i feel im gonna have to stay around 24mm
