Post by scootercy on Nov 5, 2020 18:33:50 GMT -5
Well putting a new tire on the rear and figure as long as I am here might as well change the valve stem, just incase that is the source of the mystery air loss. But what size is the valve stem? Yahama part is 93900-00802-00 but I can find no tech info on it. Anyone replace theirs with an auto part store replacement?
Post by pinkscoot on Nov 5, 2020 19:06:36 GMT -5
You should always replace valve stems when you replace the tire. They are a cheap insurance policy. I've gotten ones from NAPA when I forgot to order them. Make sure you replace them with like ones, if short go short if angled go angled. If angled match the side it sticks out.
df41590
Post by df41590 on Nov 5, 2020 19:13:20 GMT -5
Looking at the picture on partzilla it looks like it is the .625" style. www.partzilla.com/product/yamaha/93900-00802-00I'd just take the old one to a parts store and compare, as far as I know valve stems only come in 2 sizes(.453" & .625"). Also recommend picking up a can of bead sealer while you're at the parts store, it is great at filling in any minor imperfections between the rim and tire bead that cause slow leaks.
Post by scootercy on Nov 5, 2020 19:28:30 GMT -5
"Make sure you replace them with like ones, if short go short if angled go angled. If angled match the side it sticks out." That just for ascetics?
Post by pinkscoot on Nov 6, 2020 0:46:09 GMT -5
No its practical, makes it easier to put air in.
Post by FrankenMech on Nov 6, 2020 2:37:33 GMT -5
Clean the rim very well before you mount the tire.
Post by collinsd84 on Nov 22, 2020 21:05:17 GMT -5
Got short valve stems once from scooterpartsco.com that were right size, but seemed to be made out of hard plastic rather than rubber. Not flexible enough. Borrowed one from a neighbor that fit.
Has this happened to anybody else?
Post by FrankenMech on Nov 22, 2020 21:34:26 GMT -5
I just buy from the local auto parts store. If in doubt about size just take the old one in and they will match it.
Post by scootercy on Nov 23, 2020 2:04:48 GMT -5
I ended up getting them from a local Yahama dealership, got 6 ;-)
