Coddas
Post by Coddas on Nov 9, 2020 8:47:02 GMT -5
I decided it was time for something to drive in the winter instead of my Aerox and i got this one Had it for 3 weeks today and i love it . As i live in Sweden and this is classed as Moped with max speed of 45km/h i will keep it slow , i can still make it look fast/cool?
Coddas
Post by Coddas on Nov 9, 2020 9:15:18 GMT -5
First project is clean up in the rear so have/will order some parts to move the plate and smoked taillight/indicator then there is other small stuff i want change too . Made this order on MAXISCOOT.COM . The shock is meant for my Aerox , if not fit it will end up on the Sr50π
I dont see much in original mirrors and these worked good on my old sportbike so i got new mirrors too. Order and already got this Kiesler Evo undertail from TWOSTROKE.SE now i just need find or build a bracket for the plate to lowmount it down at the shock. What else can i do ? Sidestand , big brake kit? Stickerbomb it π€£?
Post by pinkscoot on Nov 9, 2020 9:59:17 GMT -5
On my SR50 I just took some 1" aluminum angle and drill holes to mount it into the existing spots under the existing tail.I'll get pictures later.
Post by aeroxbud on Nov 9, 2020 14:19:41 GMT -5
Looks in nice condition. You can make the HI-PER2 engine quite fast if you want too. π
Coddas
Post by Coddas on Nov 9, 2020 15:16:27 GMT -5
On my SR50 I just took some 1" aluminum angle and drill holes to mount it into the existing spots under the existing tail.I'll get pictures later. I know what you mean but i want it down low . was thinking like this Looks in nice condition. You can make the HI-PER2 engine quite fast if you want too. π Yeah i had a Derbi Gp1 17 years ago with that engine and it was fast with just variator weights and exhaust
Post by pinkscoot on Nov 9, 2020 20:37:22 GMT -5
I forgot you have those square plates. That looks like a great solution.
Coddas
Post by Coddas on Nov 19, 2020 19:06:23 GMT -5
I got most parts now for cleaning up the back and move my licenseplate but been busy with work and now is so cold and i dont really have any place to work on my scooter thats not as cold as outside. Got this used 280mm rotor from a german seller on ebay for a Yamaha Aerox that should fit the Aprilia Sr and a new RPM caliper . Now i just need a bracket so i can fit the caliper to the Sr. Been looking for a sidestand and is so confusing with what years fit for what engine Minnarelli ,Morini or Piaggio. I orderd one that should fit new frame with piaggio engine but when i got it and read the small instruction paper it say 00 Di-tech and im sure they had Morini back then and another frame , but there was a spacer included for Piaggio so guess i just have to test it I post more when there is anything to share
