Post by yambw’s on Nov 26, 2020 11:07:34 GMT -5
I have always used Dedicated gear oil but I have come across this in the service, motor oil !? Is that what it means actual engine oil ?
Post by 90GTVert on Nov 26, 2020 12:19:07 GMT -5
Yeah, that's not uncommon. The viscosity of that motor oil is very similar to common viscosities of gear oils. They are rated a bit differently. I still prefer a gear oil. It may not really matter, but I like the idea of an oil designed for the task at hand.
Post by yambw’s on Nov 26, 2020 12:29:33 GMT -5
Thank you
Post by aeroxbud on Nov 26, 2020 15:01:09 GMT -5
If that's the manual for the prebug, things have changed a lot since then. The first time I serviced my wife's scooter. It said to use an oil viscosity rating that isn't even made any more! There is such a small amount of oil in the gear box. I prefer to use proper gear oil.
Post by yambw’s on Nov 27, 2020 4:18:11 GMT -5
If that's the manual for the prebug, things have changed a lot since then. The first time I serviced my wife's scooter. It said to use an oil viscosity rating that isn't even made any more! There is such a small amount of oil in the gear box. I prefer to use proper gear oil. Yes it is and I guess 30ish years old now so as you say alots changed I will stick with dedicated gear oil Thank you
