Post by ApeShit70 on Nov 26, 2020 20:06:46 GMT -5
So, the crankshaft that malossi recommends for my cylinder kit is probably one or the most expensive on the market. CRANKSHAFT MHR TEAM PIN Ø 12-13 ROD 85 (STROKE 39.3 MM) Now can I use any crank that has a stroke of 39.9mm? That crank is close to 600$ they also recommend one that's only 2something$ is the more expensive one really worth it? What's the benefits of the more expensive cranks over the cheaper ones? They all rotate on bearings? And they are all quality. Not Chinese!
