Post by nikola11 on Dec 11, 2020 17:58:56 GMT -5
Hi guys, For some reason I do not have any luck finding a set of main jets for my stock 2003 Yamaha Zuma carburetor. The carburetor is a Tk 14mm carb. If I am right the main jet has 6mm threads. I am looking for jets from 80 and up so I can get it tuned well for a new pipe. Could anyone help me with finding a jet kit online? I am located in Europe so it would also help if the webshop was in Europe to keep shipping fees minimal.
P.S. I am sorry if this is the wrong section of the forum for a question like this. Thanks
Post by Zino on Dec 11, 2020 19:14:30 GMT -5
mikuni 11/22 jets will fit or dellorto 6 mm fit
Just buy a large range because a yamaha 80 does not flow like a mikuni 80.
I found for genuine mikuni I needed about 5% larger 85 to get better cylinder temps as the 80 .
If you are running stock air box with a pipe and kit low 80s to mid 90s will get you in the right place . If you are going open filter get some get some that you another 10 points
Post by nikola11 on Dec 12, 2020 6:52:44 GMT -5
I have a large set of 6mm dellorto jets that I have from other projects but if I remember correctly I have tried using 6mm Dellorto jets in the stock Zuma TK carb and I had no success. Are you shure that 6mm dellorto jets work? I will give it one more try then.
I have an Athena 70cc kit and the reason I am looking for jets is because I have aquired a Gianelli Extra V2 pipe and would like to try it out to see what can be gained with that pipe. And yes, I am running the stock airbox.
Post by captincvmn on Dec 12, 2020 7:04:47 GMT -5
I bought this set from Amazon Glixal Jog 50cc 72cc 1PE40QMB... www.amazon.com/dp/B06XHY4Y9H?ref=ppx_pop_mob_ap_shareHope the link works. I’ll see when I post reply. It goes by 5’s up through the range. For fine tuning you need smaller steps but for most things I think going by 5’s isn’t horrible. These jets fit my stock Chinallorto
Post by Zino on Dec 12, 2020 8:54:06 GMT -5
I have used the mikuni jets for the yamaha stock carb . Currently on my 2 vinos I have bought that glixal set off amazon that captaincvm lists.
Others have used the 6mm dellorto jets purchased off scootertuning.ca the m6 jets that go in the 17.5 mm carb
Post by geoffh on Dec 12, 2020 10:07:07 GMT -5
You could try WWW.KMTPRODUCTS.CO.UK part number M6075-TK-04 6mm fit my dellorto carbs decent price as well. Geoff
Post by nikola11 on Dec 13, 2020 8:53:32 GMT -5
Thank you guys for the links and advice. I will try once more with the Dellorto 6mm jets that I already have. I must have done something wrong the last time I tried the dellorto jets.
If they do not work I will have to source one of the jet sets linked above.
ihoverboard
Scoot Junior
Post by ihoverboard on Dec 17, 2020 2:08:44 GMT -5
