Post by CrankingWithCG on Dec 23, 2020 0:56:55 GMT -5
Been possibly toying around with Zuma stuff. Prebug, a MVS 70cc bore with a doppler 12mm crank would be how many ccs? Anyone know?
Edit: nvm im a dumbass and assumed it added 12mm stroke, but its the wristpin. So its 70ccs 😂
But, ive got a setup to toy with a bit. That pipe and bore, stage 6 intake, v force reeds, most wicked exhaust, pwk 28mm, an overrange, probably La Furio Rossa, stage 6 clutch, mvt ignition. How nasty would this setup be on a prebug? I got some stuff planned
Post by Zino on Dec 24, 2020 8:19:46 GMT -5
Prebugs are easy to make fast Pig Prebug was ridicously fast and you have a lot of similar range parts .
You have the pipe kit and carb and trans to get you upper 60's And the Ignition to keep up past 12000 rpms If you have gears in that 10 to 11 to 1 range push over 70 mph
Post by CrankingWithCG on Dec 25, 2020 17:39:01 GMT -5
Prebugs are easy to make fast Pig Prebug was ridicously fast and you have a lot of similar range parts . You have the pipe kit and carb and trans to get you upper 60's And the Ignition to keep up past 12000 rpms If you have gears in that 10 to 11 to 1 range push over 70 mph Everyone always said that prebugs are hard to make power on. But from what ive seen floating around....me scared of what im getting into 😂
