0weng
Post by 0weng on Jan 1, 2021 13:09:20 GMT -5
Guys, need help on how to properly set up and install my S6 tacjometer. I wrap aroind the qire on the ignition cable but the rpm readingbis glitchy. It just randomly jumps all over rev. range.
0weng
Post by 0weng on Jan 1, 2021 13:16:02 GMT -5
Post by aeroxbud on Jan 1, 2021 13:38:42 GMT -5
You might have interference from a plug. But more likely not getting a good reading from the coil wire. Did you set the display to one fire per revolution?
0weng
Post by 0weng on Jan 1, 2021 14:33:17 GMT -5
Yes,it was set at p-1. I am not sure how to properly attached the rpm wire on the ignition coil. Theres this extra black wire that i dont know where to attached. Ive seen videos where they didnt attached the black wire and just wrap the white wire on the IGN cable. I will attached a link on how i wrap the white wire. Ps. After i wrap the white eire around i secured it with elec.tape. drive.google.com/file/d/1-xN38BxwSGTwJYkq1aRaALA0ufXoXp_v/view?usp=drivesdk
pewpew
Post by pewpew on Jan 1, 2021 15:40:45 GMT -5
you need to install the tach black wire to ground and white wire to stator
Post by aeroxbud on Jan 1, 2021 18:24:34 GMT -5
0weng
Post by 0weng on Jan 1, 2021 19:50:08 GMT -5
Thats what I thought. Theres another set of wire that looks similar to the phoyos. Thanks guys!!I'll give it a try next time i start my build.
