Post by crosscreek on Jan 2, 2021 17:19:39 GMT -5
I am fitting a prebug Zuma into a 1946 cushman. I have no idea how the coil, oil tank, and wiring loom is attached to the rear of frame. Would any of you be able to provide a photo with all your plastics off detailing the connections? Any help is incredibly appreciated.
Post by aeroxbud on Jan 2, 2021 19:16:11 GMT -5
On my BWS, same as prebug. The wiring ran down the right side as sat on the vehicle. There was a brackets for the coil and oil tank to mount to the frame, with bolts. The oil tank need to be higher than the pump. So gravity feeds the oil to it. Apart from that you could mount it anywhere. The loom is just held in place by zip ties.
Post by yambw’s on Jan 3, 2021 3:22:34 GMT -5
Post by yambw’s on Jan 3, 2021 3:26:29 GMT -5
Post some photos of your build
Post by aeroxbud on Jan 3, 2021 9:16:04 GMT -5
That's so different to my 2002 model!
Post by yambw’s on Jan 3, 2021 10:09:33 GMT -5
That's so different to my 2002 model! Did they completely redesign the bws from the ground up In 2001? my bike is running the 2007 loom cdi and engine from witch I had a donor bike and as you said very different under the skin. I did route all the wiring ect as it was from factory on the prebug
Post by aeroxbud on Jan 3, 2021 12:44:31 GMT -5
I think they did. It got under the seat storage too where the tank is. And a little panel, from which you can get at the spark plug.
Post by crosscreek on Jan 5, 2021 23:06:01 GMT -5
Post some photos of your build Many thanks! This is exactly what I needed. I didn’t see a way to post photos of the scoot. I just got done with the wiring. It looks like a clunky 40’s cushman. But it’s a fun Yamaha Zuma at heart!
Post by crosscreek on Jan 5, 2021 23:10:12 GMT -5
I think they did. It got under the seat storage too where the tank is. And a little panel, from which you can get at the spark plug. I have a 2008 yamaha Zuma as well that I was going to use as a donor and they are completely different. 89-01 used the vertical Minarelli motor. Inside the belt case it says made in Italy. 2002 later has the horizontal motor and relocated gas tank further back and oil tank to allow the large trunk storage. The front end of prebugs are way lighter so they are easy to wheelie. The 2002 later feel a lot different.
Post by aeroxbud on Jan 6, 2021 6:44:09 GMT -5
I think they did. It got under the seat storage too where the tank is. And a little panel, from which you can get at the spark plug. I have a 2008 yamaha Zuma as well that I was going to use as a donor and they are completely different. 89-01 used the vertical Minarelli motor. Inside the belt case it says made in Italy. 2002 later has the horizontal motor and relocated gas tank further back and oil tank to allow the large trunk storage. The front end of prebugs are way lighter so they are easy to wheelie. The 2002 later feel a lot different. The 2002 model here is still a vertical motor. That's why it has a removable panel in the helmet storage, to get to the plug.
Post by yambw’s on Jan 6, 2021 6:54:20 GMT -5
Oooo that slider, even has the oem mirrors 😍! Do you still have it Aeroxbud ?
Post by yambw’s on Jan 6, 2021 6:56:28 GMT -5
I’m sure all bws had the vertical engine
Post by crosscreek on Jan 6, 2021 20:43:34 GMT -5
I’m sure all bws had the vertical engine Interesting. My 1998 prebug is vertical and all my bug Zumas have been horizontal.
Post by crosscreek on Jan 6, 2021 20:46:08 GMT -5
Post by crosscreek on Jan 6, 2021 20:52:55 GMT -5
